My Review - G23: 550 & 450 hp engines
  • ironj32
    • May 2011
    • 600
    • 2018 SAN G23 XR550
    I finally got my butt into a 550hp super charged G23, today. For those of you who are not familiar, I own a G23 with the 450hp engine. The sole purpose for my personal boat is to wakeboard. The reason I wanted to try out the 550hp was to see if the wake was any better, with the capability it has for extra ballast weight. Below is my review. Please realize that this is all just my personal opinion (besides the #'s), but I know there are people out there who are not sure what engine they want to get, so I've given my thoughts on the other areas I know are of interest to people as well...hopefully this will help you to make a more informed decision.
    Ballast setups.
    450hp: Factory plus 450 each rear compartment, 200 under midship seats, 750 in bow.
    550hp: Factory plus 750 each rear compartment, 250 under midship seats, 1000 in bow.
    Wake - The extra 950 pounds that the 550hp engine can handle (factory + 3000) does not make a noticable improvement over the 450hp setup (factory + 2050 pounds). This is in-line with what the Nautique team riders first told me back in May when I ordered mine...there seems to be threshold with where the wake basically maxes out in size (that threshold is describe above with the 450hp ballast setup).
    Some may ask, "why do any extra weight over factory, at all?" The wake does not get any bigger with the extra ballast (because you can ride slower and with a shorter rope), however, the wake gets harder with the extra weight. For my friends and mine riding styles, that suits us best...basically grip it and rip it.
    Boat Performance - The 550hp definitely takes the turns much better...like a slalom boat. The time to get up to speed during starts was not a huge difference, but remember, we had nearly another 1000 pounds in the boat, compared to what I have in the 450 (plus it was a smaller prop). I'd imagine that if you had only factory + 2050 lbs, that you'd notice it get to speed much quicker. Top speed was a no brainer, much higher on the 550hp. I didn't take all the way up, but when I hit 38 mph, we were only at about 3900 rpm. Top speed with the 450 is about 38mph at 5500 rpm.
    Engine Noise - To me, I didn't really notice a difference.
    Conclusion - The only real benefit of the 550hp engine is that you'll get to speed quicker, take corners better, higher top end speed and run lower rpms. The wake between the 450 and 550 is equal, as is the noise. Again, this is all my personal opinion, and I'm sure there will be others out there with one that differs. I could definitely see the extra engine being a huge benefit for those that live on small lakes and need to get to speed immediately. This thread is not intended to promote one engine over the other, but is meant to just provide some real life insite
    2018 SAN G23 XR550
    2015 SAN G23 XR550
    2014 SAN G23 XR550
    2013 SAN G23 XS550
    2013 SAN G23 ZR450
    2011 SAN 230
    2010 SAN 230
    2000 XStar
    www.mnspringride.com
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    Come on now. Go longer not shorter. That is a solid to the point review though for perspective buyers.
    • ironj32
      • May 2011
      • 600
      Are you refering to the rope length? I personally, like to have as long as rope as possible. I was just saying that when you ride with less weight, you can ride slower and with a shorter rope. This is why I like more weight
      2018 SAN G23 XR550
      2015 SAN G23 XR550
      2014 SAN G23 XR550
      2013 SAN G23 XS550
      2013 SAN G23 ZR450
      2011 SAN 230
      2010 SAN 230
      2000 XStar
      • biggator
        • Sep 2012
        • 208
        • lake lanier
        • G23
        Thanks for the review.
        I just ordered mine with the 450.. after riding it stock, I doubt I'll ever bother to add more ballast. One of the things I liked most about the G was that it was the first boat I've ever seen that didn't NEED to add weight to get a world-class wake. I tested the Xstar - which comes stock with 1400(?!) which means you have no choice but to eat up all the storage with plug/play ballast.
        I loved the stock G wake.. and all the big huge storage!
        • Casey@NautiqueMN
          Banned
          • Jul 2010
          • 47
          • Minnesota
          Did you just order your's from Konrad at MarineMax? He is the man and I work closely with him up here in MN. Congrats!!!
          • schaabj
            • Oct 2011
            • 140
            • Canada
            • 2013 Super Air G23
            Awesome review ironj32!!
            I am very happy with our G23 with the 550. I wouldn't suspect that the wake would change between motors but that is interesting about the noise. I have not been in a Nautique with the 450, however I know the 409 was SUPER LOUD!
            Also interesting about the weight not affecting the wake past a certain point ... I guess to go bigger Nautique will need another major hull design or some sort of transom mounted hardware like Malibu does ...
            • biggator
              • Sep 2012
              • 208
              • lake lanier
              • G23
              That's him!
              • CradGen2
                • Aug 2020
                • 1343
                • Horseheads NY
                Not in the market for a "G" ride, but this is a great review of the boat motors. thanks for sharing.
                Also it should do away with the can I use a 409, which I think Jeff mentioned several times wouldn't work.
                • Laketexoma
                  • Dec 2004
                  • 463
                  • Lake Texoma (Texas side)
                  • 2023 G23
                  Thanks for the review. Ever since I have ordered mine I have debated if I was going to disapointed in the 450. We will ride stock ballast. I drove the 450 and thought it was ok, but I'm a gear head and always want more power. Thanks again..
                  2016 G23 H6
                  2014 G23 550
                  2013 G23 450 (Great boat)
                  2000 SAN ( Loved that boat)
