Scott, shore erosion from waves (ocean or wakeboat) can be a major expense and PITA. People who bought houses more than maybe 5 or 10 years ago didn't sign up for having to rebuild their riprap every few years because of wakeboats. On inland lakes, like in MN, most people would have to redo their riprap maybe every 30 years. Now some people are having to do it much more often and build much more extensive systems. What use to be $45 per linear foot (in 2013 $'s) every 30 years is now $140/ft every 10 years. They're basically beginning to build on inland lakes what was just for Superior. That's quite an increase in expense - caused by wake boats. And redoing the riprap also often involves redoing stairs, decks, patios, and such near the riprap. Erosion is expensive. On top of this is potentially greater wear & tear on docks, boatlifts, and such.
Besides the additional cost, there is also the PITA of having shoreline torn up and often unusable while the work is being done.
I don't want to see bans and once they start they'll multiply. Anything we can do now to mitigate the screaming will be helpful. Are your power turns necessary? Can you reduce the amount of time you surf? Can you sometimes board with a bit less wake?
