Does anyone know if there is a way to calibrate the air and or water temperature guages on our boats?
it seems that it typically is 5 degrees off on both
As far as I know, you cannot calibrate these features, but a +/- 5 degree variance isn't too bad considering the environment boats are used in. The water temp probe is in your paddle wheel, and I believe the air temp probe is under the helm.
