So we have a 03 226 TE with zr6. Our first Nautique. Looking at 230s because I really like snap in carpet and the fact that the inside is all glass. I'm certain that these boat are considerably more solid through rough water than our 226. However the 226 is great! Even appears that the 226 has a deeper v hull than the 230 just looking at it. Of course I want bigger better wake. My question is how much bigger and better wake on the goofy side is a 230 going to be than my 226. I can't afford a G or I would not even ask this question. My thoughts are the market is going to be full of 230s because of people wanting the G.
Tags: None
I can't compare it to the 226 but the goofy side of my 230 is good, but you have to weight it down. I use a 750 in the locker, a 750 across the back on the floor, 300lbs of lead in the nose, all factory full except for the port side. I use to put the 750 in the seat instead of the floor but gave up on it, because the boat leaned over so far that it was scary.
With this setup I still get a good push 15' back from the tower. I use a 20' rope.2013 G23 450 with NSS (175hrs) and still have the original prop
2010 SANTE 230 343 (280hrs)
