I bought a 210 Super Air at the end of last season with 135 hours. After this year it had 170 so I figured I'd change the oil as part of my winterization. When I pulled the dip stick to check the level to make sure all the oil had been drained the end was GONE!! Side note I should have checked earlier and thought I did but evidentaly I was wrong. Long story short the dealerships in my area wanted $2500 to pull the engine and check the oil pan... Ouch!
So I decided to tackle the issue myself and removed the rear dividers and tanks. The oil pan is bolted on with about 16 small bolts and most are easy enough to get to except the two front on the port side behind the starter. Side note I also removed the knuckle where the easy drain attaches to give the pan a bit more clearance. The gasket is a one piece and luckily stayed attached to the engine block and the pan dropped enough without raising the engine for me to reach in and check for the broken end of the dip stick. As it turned out there was nothing in the pan so it must have been broken from the previous owner, so I reattached the pan, resealed the knuckle and am good to go. But I figured I'd throw this on here as an option if you end up in the same situation and don't have $2500 to go fishing in the oil pan!
