Surfing Behind a Super Air?
  • Luke
    • Mar 2003
    • 509
    • Des Moines, Iowa
    How does everyone weight their Super Airs for surfing? We have tried a ton of different setups, but we are still looking for the perfect configuration.
    Here is the best setup we have found so far: (I have a ’03 210 Team)
    -Port Ballast Tank full
    -Starboard and Center tanks empty
    -550 lb fat sack filled as much as possible sitting on top of the ballast tank on the port side. (I’d estimate about 300-400 lbs)
    -250 lb sac on the rear seat, shifted to the port side.
    -4 people sitting along the port side of the boat on the seats
    We run at about 9.5 on Perfect Pass.
    Wake seems to be the best with a full tank of gas. (
    Even this seems to change quite a bit, seems really hard to get a consistent wake to surf and often the wake washes out a lot. I recently looked through the LevelX Surfer magazine and noticed that they recommend riding around13-15 mph and also a little different weight configuration, so I’m really interested to hear what everyone else is doing.
  • SprintCar39
    • 224
    • Willard
    Here is what we found to work the best for us. This was behind a '03 Super Air. We were very happy with it and it was also very consistent.
    ->Port Ballast Full
    ->Starboard Empty
    ->Center/Belly FULL
    ->600 lb Fat sac on top of Port Ballast...est 500 lbs.
    ->400 lb Fat Sac on floor along port side
    ->400 lb Fat Sac on floor in bow area
    ->3 people would sit on port gunnel
    ->10 MPH used a GPS to make 100% sure
    We tried many different configurations and this was the best. We also used a Hyperlite Landlock and BroadCast.
    • Luke
      • Mar 2003
      • 509
      • Des Moines, Iowa
      Thanks for the info, we'll give that a try.
      What do you think of the Broadcast? I think the Landlock is a decent board to learn on, but seems to be pretty limiting after you know what you are doing.
      • holmes
        • Oct 2003
        • 18
        • Minnesota
        Its not easy to get a good wake for a Regular footer riding frontside. I was at Gators house during Surf Expo week and we surfed only with the Starboard wake.
        Boat Fully weighted
        + 2 sacs in front
        + 2 sacs in back
        +all internal ballast full
        and 5 people!
        Loaded, I'll post some pics!
        Landlock boards
        • wakeborder5
          • 4
          • Commerce, Michigan
          I usually fill the starboard balast tank full and center balast tank full and then sometimes throw 600lbs on top of the tank and usually 9.5
          • RAB
            • Jan 2004
            • 52
            Is it at all possible to surf without any extra weight besides the Team 210 with full ballast?
            • BIGMAC
              • Dec 2003
              • 94
              • Fort Mill, SC
              RichardBrowne, Yes. My friend does it all the time. If you have people just have them to get to one side.
              • Luke
                • Mar 2003
                • 509
                • Des Moines, Iowa
                MAC, how many people are usually in the boat? I'm assuming they must ride on the starboard side?
                I tried no additional weight and about 4 people on the port side, but didn't care for the wake much.
                • BIGMAC
                  • Dec 2003
                  • 94
                  • Fort Mill, SC
                  It was the port side. I think port. Isn't port the left side? Anyways we filled the center and left tank then moved 4-5 people to one side. I think since most Nautiques props spin opposite then the starboard side would produce a better wake. Also I don't know if it was a good wake or not but my friend was able to ride it around pretty easy.
                  • Hollywood
                    • Sep 2003
                    • 1930
                    • WIIL
                    No, since they spin opposite that is why the port side is better. The starboard side is going to be pushed up to make up for the driver's weight and port pushed down incase there is no spotter. I don't known if that was the reasoning behind it, but it seems to be the most logical explanation I can come up with.
                    • ag4ever
                      • Feb 2004
                      • 1180
                      Nope, it is so that when you pull up next to a skier, and kick it into reverse the back kicks out away from them, and won't run them over. That is if you pickup the skier on the driver's side.
                      BTW,
                      Port = four letters & Left = four letters
                      Starboard > four letters & Right > 4 letters
                      This is assuming you are facing the bow, not the stern, and not with your keel in the air, but the deck facing up.
                      • carb02san
                        • Dec 2003
                        • 36
                        We could never get near as nice a wave on the port side as we can on the starboard. I just decided to learn how to surf switch and it did not take as long as you would think. The difference in the wave is huge!
                        All tanks full, fat sack on floor starboard side, side sack on rear seat to starboard, side sack on top of starboard tank, people on starboard side.
                        The wave is about waist high. I'll post a pic as soon as I can.
                        • Bezerko
                          • Jul 2005
                          • 12
                          • Sunshine Coast, Qld, Australia
                          We have a 2004 210 team and this is how we load it:
                          Factory tanks full
                          175kg lead on the drivers side rear tank
                          150L Fatty as full as we can get on the drivers side rear tank
                          250L Fatty on the floor behind the drivers seat
                          Sometimes a 150L fatty on the back seat.
                          Usually 2 people on the sun deck on the drivers side, driver, 1 in observers seat and 1 in the bowrider.
                          • Laptom
                            • Oct 2003
                            • 876
                            • Eindhoven, Netherlands
                            That's a surf wake Yellow_Flash_Colorz: !!!
                            • imported_pjdave
                              • Jan 2004
                              • 90
                              • brisbane australia
                              [quote="ag4ever"]Nope, it is so that when you pull up next to a skier, and kick it into reverse the back kicks out away from them, and won't run them over. That is if you pickup the skier on the driver's side.
                              I asked Scott Mohr ( former engineer and wakeboard team manager at nautiques) why the props spin opposite in nautiques, and he said is was to counter act the weight of the driver. He said its not a problem with an observer but some pro skiers/wakeboarders train with no observer so it spins opposite to keep a consistant wake. ( saying that, this was all before ballast was an option) ,
