Hey guys, I was wondering what you guys think about the break in period, Some say to not even warm the boat up the first time and just immediately into the cruising part o' the break in period.(Or ever in that matter) His reasoning behind this is that motors are "tighter" when they are cold (true, a new motor makes this even more true, since the clearances of various parts have not had the chance to properly mesh/wear to each other.) so in order to decrease wear it's best to warm up the boat as quick as possible. I, however, have always let the old boat warm up to its normal coolant temp of 160* before riding behind it or driving it anything above idle gear. I know its always good to warm the oil up before going WOT or running the motor hard.
The other interesting think I've heard lately (well this is kind of random) but some people (S4 car guys) say to run the car easy for the first thousand or so miles (I think it was something like that) and then drive it how you are going to drive it. Meaning romp the crap out of the motor, or drive it like a granny. The theory behind this is: it would allow the rings to seat properly according to your driving style.
However other manufactures seem to avoid WOT for the first 5 or so hours. So, what do I do? I know that breaking in the motor isn't really all that important, so long as you are not "breaking it in" at the dock, you'll probably be fine. I know it's not a science, and that a lot of it is over cautious (read initial 10 hrs of break in before running stock ballast exc.) so as to keep early engine replacement to a minimum.
Malibu seems to recommend to wait until the first 10 hrs are up to run ballast. This seems about right, but what about pulling a wakeboarder? 5 hrs? I understand that the idea is to keep the stress down on the motor so that the piston rings and other various internals can shave down and co exist happily for the rest of the motors life.
The motor I will have will be the Excalibur, but I doubt its any different from the ZR6 break in wise. It's going to happen quick though. (I will probably have 10 hrs on her in 2 days, so I can go riding. :mrgreen: )
Thoughts? Opinions? I'm going to be following PCM's break in procedure, but I was wondering if anyone else had anything to add to that. It seemed to differ from what I read in the CC owners manual.
Cheers,
Richard (24 more days till delivery(5-22-05))
PS: Is it bad that I've already read the owners manual? :shock:
Cheers,
