Originally posted by scottb7
View Post
Sorry I couldn't edit last post for some reason. After actually watching the video, I was able to answer my own question. The video states that these extend "several" centimeters. It might be exactly what is needed. A basic kit costs $740 on Ebay. That would just give you extention on the sides. To include the bottom would be more of course.
I think my plan is to make a prototype using 1/8 inch aluminum and see if a side mount improves my wave. Then I will try side and bottom which would be in line with the Nautique system. They will be static systems to start but if they can do the job then these systems might be the way to go. This product would allow for a very clean install.
As I have learned from my previous experiments, this is a trial an error business. Without some sort of hydrodynamic modeling system, it comes down to some smart guess work and then going for it. I hope a few other people get the itch as well. -Marc
Originally posted by NautiqueJeff View PostYes, there is a software update that allows for detailed control from the LINK. You would also need to add the wiring and the two devices to the transom.Current - SAN 230 TE
Sold - 08 Calabria Pro v2
Based on the installtion instructions http://great-water.com/store/PDF/man...%20install.pdf the tabs extend 35mm.
Based on info on the web, you need to make sure you mount them on a flat surface or shim them properly so that you don't get binding. They show some mounting guides as well. Basically you are going to need 12" of straight edge to work with so that they mount properly. I don't have access to my boat or I would have been out measuring the back to see if they will fit.
If they don't fit, you could use something like the Lenco actuator ( http://www.lencomarine.com/index.php...nd-accessories ) but have them just sliding the interceptor panel out. That would let you build a custom aluminum panel that matches the edge of your hull. Once that design is done, we just need to have templates for each hull shape and you could fit that on any boat. But I agree it would really be trial and error to get it right without someone who really understands fluid flow.
Good news is that there are enough different parts that are designed for real marine use so you at least know they can handle the water, etc.
Marc - how do you plan to hold the side plates in place for testing? Bolt/clamp to swim platform mounts?
Originally posted by moto822 View PostI have the 2010 SANTE 230, I am assuming my LINK is 1.0 but not 100%. Does anyone know if this will work? If not that is pretty disappointing they didn't find a way to integrate.
Originally posted by ES View PostSame situation for me as well (2010 210 SANTE), but from what I am reading, we are out of luck. I wonder if the connection with LINK 2 is also needed to adjust steering...with some much drag on one side of the boat, I would assume the system would compensate for it somewhere in the software?
I just heard from my dealer and he informed me that the current solution is for the 2.0 only. He did inform me that they are aggressively working on a solution for the SANTE 2010/2011. I will post if I hear more.Current - SAN 230 TE
A d m i n i s t r a t o r
- Mar 2002
- 16524
- Lake Norman
- Mooresville, NC
That's fully-extended.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by dfoster View PostBased on the installtion instructions http://great-water.com/store/PDF/man...%20install.pdf the tabs extend 35mm.
As for the folks with the older boats w/o Linc 2.0, don't lament. If the parts can be sold by dealers direct to boat owners, the retrofit would be simple. Yes, the wiring would be a manual setup but it would be easy. The real issue is getting a plate prebuilt with the right hull shape. I happen to own a '99 SN so I know none of the designs out there will ever work for me. I have to build something myself or it's just a matter of leaning the boat over with sacs laying all around until I can upgrade to a Sport 200. Luckily, I live on a lake so I have plenty of time for experimentation.-Marc
Originally posted by scottb7 View PostIt will be interesting to see how far out the nautique system actually protrudes compared to CL system. This picture shows out somewhat...But maybe not fully.
Originally posted by NautiqueJeff View PostIt does not replace the NCRS. Look at the picture on the first page of this thread. You can see both systems in place.
so is the NCRS a horizontal wake plate in the middle of the hull - same locaiotn as the old hydro gate?
- Mar 2002
- 16524
- Lake Norman
- Mooresville, NC
