Nautique Surf System
  • scottb7
    replied
    I wonder how much $ and if someday nautiqueparts could get all the bolt on stuff and then we (2011 and earlier with/without linc) could rig some switch like this. This type has led's showing the in/out level for both sides. i get that it would not be as good but it would be pretty sweet. Are the new nautique ones elec or hydraulic?
    Leave a comment:
  • High altitude
    replied
    Thank you! If you get the opportunity to take pictures... I know a lot of us would appreciate it. -Marc
    Leave a comment:
    replied
    I am going down to check this out firsthand on January 15. I'll give a full report.
    Leave a comment:
  • High altitude
    replied
    Has anybody actually seen one or is it all from the website? I have seen multiple pictures and I can't tell if the waveplates come out perpendicular or at an angle. It would seem that coming out at an angle would be impossible (based on the plates) but I have seen a few pictures that make it look that way. Thanks. -Marc
    Leave a comment:
  • High altitude
    replied
    Already started working on my design. I built some "surfgates" last year and tested them... but I was not impressed enough to keep them. Some of the guys with older Malibu's have seen some amazing results but I couldn't dial it in.
    The last day of testing was in 38 degree water so maybe I didn't wring out every possibility!
    Leave a comment:
  • MTRBTR
    replied
    I really like the basic design of this.
    I know like people have said, Nautique is probably not ready to make an aftermarket version of this but it seems like for those of us that own older boats that you could develop a manual version of this pretty easily that would not have to be part of any electrical system. Pull a pin, slide it in or out etc. Someone should develop that!
    Leave a comment:
    replied
    No, unfortunately it will not. You need LINK 2.0 in order to use the NSS.
    Leave a comment:
  • NautiqueGreek
    replied
    I have a 2011 SANTE 210, do you think it will work with that version of the LINC system ?
    Leave a comment:
    replied
    Originally posted by ViSoR View Post
    So if you have a 2012 210 with Linc 2.0 you can install this?
    Sure can! You'll need the two plates for the transom, the wiring, and a software update for the LINK.
    Leave a comment:
  • MinnesotaNautique
    replied
    Originally posted by NautiqueJeff View Post
    I can tell you that they have NOT tested this on the 200 Sport yet. They have said that they plan to test it at the factory, but that as of right now the plan is only to offer it in the Super Air Nautiques.
    I hope they work it out, lot's of 200's out there...
    Leave a comment:
  • ViSoR
    replied
    Leave a comment:
    replied
    Originally posted by riverrat0612 View Post
    I was told by my dealer that it is not going to be available yet however, for 2014 this will be an option and there should be a retro fit for any 200 sport with the Linc 2.0
    Leave a comment:
  • robertsmcfarland
    replied
    I'm wrong, I think its 2600 if installed at the factory.,retro fit I think you would have to add labor to that price
    Leave a comment:
  • robertsmcfarland
    replied
    I think the price 2500 if done while being built at the factory
    Leave a comment:
  • riverrat0612
    replied
    Leave a comment:
