FCT1 board rack replacement/fix
  • jtohara
    • Nov 2010
    • 6
    • Lake Lotawana
    • 2001 Pro Air Nautique
    Without any success, I have been looking for racks to fit the rectangular cross beam on the FCT1 tower. After inspecting the racks today, I noticed they are actually Skylon. Is this OEM? The curved aluminum that the bungees hook to are broken off of the forks. Does anyone else have this set up? Do you know if replacement forks are available? If not, are you removing the racks entirely and replacing with racks that fit on the round tubing? Also, I'd like the racks to be black so they match the tower, but it seems like most options are chrome.
  • jtohara
    • Nov 2010
    • 6
    • Lake Lotawana
    It looks like Flight Clips are the OEM for the FCT1. On first glance, I wasn't sure how those are set up, but have found a few pics online of boats with this option. That option is too expensive for a reasonable replacement option, so the search continues. I'm guessing the Skylon option that I have was an after market add on. Probably worth mentioning I'm not the first owner of the boat, in case that wasn't apparent. Any guidance/help is appreciated.
    • yager97
      • Apr 2010
      • 33
      • Ontario, Canada
      • 2004 Nautique SV-211 Team Edition
      I suggest just replacing with racks that fit on the tubing. Check out onlyinboards.com for a good selection of Wakeboard and surf racks in the accessory section.
      Sent from my Vox using Tapatalk 2
