I double it, wrap it around the tower once, go underneath then put the loop over the tower. It still chews up my rope. Is there a better way?
You have a couple of options. Found this one on the net: http://www.youtube.com/watch?v=S-nef3BGSnQ
Otherwise, the way I do it, hopefully I can do justice with the description:
Lay out the rope horizontally in front of you, then do one zero shape (aka loop), leave an inch space or two and then do another zero with the top. Now lay this second loop on top of the first one and put it on the tower.
If you make a mistake and lay the first hoop over the second, the rope will slip.
A local wakeboarder pro taught me this knot and it's phenomenal...literally takes me a few seconds to change the rope length and no damage to the rope.
Originally posted by ES View PostYou have a couple of options. Found this one on the net: http://www.youtube.com/watch?v=S-nef3BGSnQ
A local wakeboarder pro taught me this knot and it's phenomenal...literally takes me a few seconds to change the rope length and no damage to the rope.2018 Ski Nautique 200 TE, H6
Originally posted by Miljack View PostThe link to youtube shows the knot I use to shorten any wakeboard/ski rope, works great! and that video makes it really easy to do...
Originally posted by biggator View PostI have a spare, cheap uncoated rope if I feel I need to tie it off shorter than my shortest coated length. I think my shortest good rope goes down to 60.. can't imagine wanting to go much shorter than that.
Originally posted by Uzj100 View PostThis is for my 9 yr old, slowly working him into longer lengths. But we're not quite to the shortest set length.
Originally posted by biggator View PostI actually run my 7yo at 70'.. she's not trying to go w2w, so I may as well give her lots of room back there. She still has no problem going out both ways.. when she does start trying to really jump, I may have to go with the very short rope.
