XR550 g23
  • Zach@n3
    • Sep 2012
    • 736
    • Indianapolis Indiana
    #76
    Clax, sorry I didn't catch that it was not availiable on your lake. I'm not trying to say you are wrong just stating there is a reason pcm says 93+ Required in the 450 manual. If im not mistaken the only differences in the 409 and the 450 are tuning. There clearly has to be some big differences in paramaters like timing and fuel maps to make that large of a difference (unless the 409 is just a detuned pig). Aluminum heads disapate much more heat than iron heads do which really allows much higher compression ratios on pump gas. Were the 500 efi iron headed engines? Just curious.
    I didn't want anymore compression on my 86 351 when assembled because I wanted to run garbage 87 in it all day long. We do 150 hours a season average so that saves some pretty good $$$. 240 hp is plenty to get anything done in that boat I need. Now the Skylark is a 10 to 1 range engine and I don't mind throwing premium at it.
    On the other hand if I were a G owner 450 would be where I would go. We just ordered the first 409 G for a customer and we are pretty curious to see how it stacks up against the 450 boats we have in the showroom. (Then again if I had the cash to own a G I would opt for the XR).
    If you can get by with lower octane then go for it (I used to run 87 in all my turbo cars when I commuted just made sure I watched the boost gauge when I was in the throttle to keep it out of the danger zone). I run 87 in the truck for every day commuting but if I am doing a long highway towing run I will fill up with the reccomended 89. (never heard a hint of detonation on a hot day yet). Clearly current combustion chamber design with modern quench areas makes all of todays engines much much less likely to experience detonation on sub par fuels. Even on a cold day in my 67 if you pull a bone head and put 87 in it it lets you know as soon as you get into the loud pedal.
    As 281 stated, an engine will run best on which fuel it was designed for. If you run premium in something designed for 87 it will not properly burn the fuel with the higher burn point thus creating less power and fuel economy from an incomplete burn. The power loss and fuel economy would be so marginal nobody would probably notice but the point is the extra cash for the premium fuel is completely negated. It has always made me laugh when someone says they want to run the "good stuff" (premium fuel) in a car to clean it out which actually creates more carbon despoits from a less efficent burn.
    Other variables go into it like elevation etc. and all that jazz so everyone may well use 87 for thousands of hours in an engine that requires premium with no ill effects. The only reason I am so apt to want to use proper octane is that boats are constantly under load which all of you know. That being said the G boat with a non lifting hull and a fully loaded ballast tank is probably the most load ever put on an engine in a wake boat so holy crap haha. Heck a 450 with no ballast will only run 38mph!
    • perry386
      • Jun 2012
      • 560
      • gadsden AL
      • Super Air nautique 236
      #77
      It makes me wonder how de-tuned the original ZR6 350 is considering that the 350, 390, 409, AND the 450 all come from the same motor. My guess would be that 350 became the 390 by a computer upgrade and the 390 became the 409 just by adding the Catanium exhaust system, and then it was tuned out to the 450. Anyone have any facts on this subject?
      • NautiqueJeff
        A d m i n i s t r a t o r
        • Mar 2002
        • 16564
        • Lake Norman
        • Mooresville, NC
        #78
        The original ZR6 was 375, not 350.
        The 375 to 390 was indeed just a software change. I know this because I replaced the ECU on my 2007 236 in order to run Zero Off, and that got me the 390 rating.
        After that, I am not sure what changes were made, but that's the info on the early engines.
        • jsta281
          • Oct 2012
          • 266
          • Utah
          • 2009 Ski Nautique LE
          #79
          I was going to avoid this topic so as to not stir the pot but I would love to see Dyno graphs for the 409 and 450. I wonder where the 41 hp is on the graph and how "useable" it is particularly on bigger boats.
          Zachary post up opinions between 409 and 450 on the G boat, curious how much different is felt.
          • 1sicknautique
            • Feb 2010
            • 321
            • Lake Allatoona, Lake Lewisville, Lake Kiowa
            #80
            I'm willing to bet 40% of all gas stations run the exact same octane in all 3 pumps and just charge more for the 91 and 93 octane.
            • jsta281
              • Oct 2012
              • 266
              • Utah
              #81
              I think all the ZR motors are based on the 6.0l GM LS2
              As for the catanium exhaust would not result in 19 hp and my 409 does not have CAT exhaust.
              • Zach@n3
                • Sep 2012
                • 736
                #82
                The ZR6 and ZR engines are different evlovements of the original LS engine family. The LY whatever GM says is one and I believe the other is a LM? Don't quote me. Thats where the extra HP comes from on the 375 vs the 409. I think the original ZR6 motors were just a good old truck 6.0 and the 409 and 450 are more like the Hi po 6.0 in the vette.
                I'm with 281. I would like to see if the horsepower is actually usable. It might be an extra 41 HP at 5500 rpm. We would have to see the dyno sheet. Everyone gets bent on the max horsepower numbers but with boats as large and heavy as the G boats you need to take a much harder look at the torque curve and output to get these big boys out of the water.
                The 550 is a boss with all of its low end torque via Mr. Roots Supercharger.
                • jsta281
                  • Oct 2012
                  • 266
                  • Utah
                  #83
                  I think I misspoke a bit in my last post
                  If I'm not mistaken the 6.0 L GM truck block was iron and came into varieties referred to as the LQ4 and LQ9 Blocks. The difference between the two in the trucks was Compression ratio with the LQ4 Having less then LQ9. (Different pistons I believe but don't quote me on that)
                  The Camaro and Corvette version LS2 block is aluminum. I'm pretty sure all the PCM blocks are steel.
                  • Zach@n3
                    • Sep 2012
                    • 736
                    #84
                    You are right but between the 375 and 409 there is different letter nomenclature that determines hard engine parts you can order from PCM.
                    Forgot about the aluminum block in the go fast cars.
                    • jsta281
                      • Oct 2012
                      • 266
                      • Utah
                      #85
                      I wonder if the ZR6 motors are the LQ4 (slightly less compression different pistons) and the ZR 409/450 are the LQ9?
                      • Zach@n3
                        • Sep 2012
                        • 736
                        #86
                        Possibly, I just can't remember the letters off the top of my head.
                        • jsta281
                          • Oct 2012
                          • 266
                          • Utah
                          #87
                          You know there is about 80 pounds difference in weight between LS2 and LQ9, I wonder if any extreme wake sensitive 196 er's have considered a block swap to aluminum? Not the most money conscious thing to consider, but plenty of CC owners have plenty of cash :-). At the point they are conscious to keep every possible thing out of the boat to reduce weight, 80 pounds is alot.
                          • Zach@n3
                            • Sep 2012
                            • 736
                            #88
                            You are correct. Thats a good idea. They are closed loop system anyways to protect the aluminum heads so why not make the ski version an aluminum block. Most 200's are ordered with the 343 anyways so that might not be enough reason to spring for the extra cash.
                            • pSchwade
                              • May 2012
                              • 127
                              • Reno
                              • 07' 220 SANTE
                              #89
                              thats only because water is considered incompressible - when you factor in compressible flow the wall shear and linet pipe length are much less of a factor.
                              Originally posted by core-rider View Post
                              OHHHH YES THEY ARE!!!! You stuff in more air, it has to come out. If anything your point is exactly opposite. It would be like sawpping out an aereator pump for impeller style without up-sizing the hoses and expecting top performance... Yes you would pump more water, but not as much as possible for that pump with larger plumbing.
                              If the cost is half as much, I see many XR550 orders in the future over ZR450's.
                              • Zach@n3
                                • Sep 2012
                                • 736
                                #90
                                Fyi, I emailed pcm about the differences in the cooling system with no reply yet.
