G23 Heater Hose Replacement
  • schaabj
    • Oct 2011
    • 140
    • Canada
    • 2013 Super Air G23
    Last year I noticed the heater hose in the rear of our G23 was a little short and could barely reach a person at the back of the boat.
    I was just wondering if anyone knows how you could get access to replace this hose with a longer one?
  • shag
    • 2217
    Try getting some 'NEW' RV sewer hose in that diameter. Wally world sells it in a kit/box that has plastic connectors. It might be a tight fit, but it will work - and be fairly inexpensive. The sewer hose is actually better imo than the stock hose.
    • robertsmcfarland
      • Oct 2004
      • 544
      • Hyco
      • 2014 g23 550
      do you have a heater hose in the back or are you referring to one behind the driver? It would be nice to have one in the rear , additional one would be nice also, when an passenger has one stuck up their shirt on a cold day they are a little sensitive when ask to share .
      2013 G23 super air
      2010 230 super air
      2009 220 super air
      2008 210 super air
      2005 210 super air
      2003 calabria pro air
      • schaabj
        • Oct 2011
        • 140
        • Canada
        I am talking just the one in the back behind the driver. I would assume it was supposed to reach all occupants of the rear of the boat, however it seems short.
        I will ask the dealer if they can put a new longer hose in. I want to stay away from adding too it, because it has to fit back through the plastic ring and I would get annoyed trying to fish it back if it were any thicker.
        • Laketexoma
          • Dec 2004
          • 463
          • Lake Texoma (Texas side)
          • 2023 G23
          The easy way to access the heater box is from the bow. If you remove the seat back there is a access hole and the heater is right there. Not sure if you knew that or not. You could look and see if its wraped around something and thats why its so short..
          2016 G23 H6
          2014 G23 550
          2013 G23 450 (Great boat)
          2000 SAN ( Loved that boat)
          • schaabj
            • Oct 2011
            • 140
            • Canada
            I was not aware of that, I will give that a try first and check. That is a good point.
            Thank You very much!
