OK, so I chose to try the 2249.... to replace the OEM 2313..... my rationale was it is the exact same specs as the 1235, only 1/2" bigger... thinking this would be the 15" equiv of the stump puller 1235. Bottom line: NOT as much hole shot as the OEM 2313, but, a full 4mph faster at WOT at 42MPH at 5625 RPM. Fully loaded OEM 3 tank ballast...verified all 3 tanks full, peed out the overflows, NCRS at 5, 76% fuel, relatively light gear on board, bimini in stowed position, 1 Mucus IS in the racks, 2x 200lb men. Average on 5 runs 0-23MPH full OEM ballast was right at 19 seconds, I would estimate 3+ seconds slower than the 2313. If as heavy as you will go is OEM ballast and no more over that, and you have long cruise runs and want to run 30MPH to and from your spots, this would be a great prop for you. If you wanna go heavier than OEM ballast either to 23mph or for wakesurfing, probrably not the right prop for you.
ACME 2249 Performance on a 450 G23
2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210Tags: None
The 2249 prop should be an upgrade on the 550hp G23's coming with the 2247 that has the 0.150 cup correct? Have you guys that run the 2313 and 2315 props noticed a nice difference with the drop in cup size? Looking for a spare prop for our 2247 stock prop.
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
I went with the 2315 for my G23 550hp. I havent tried it out yet (it is my spare and the stock works great with full ballast, extra surf ballast and ten people in the boat), but I imagine I will soon.Eric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
Originally posted by ers906 View PostI went with the 2315 for my G23 550hp. I havent tried it out yet (it is my spare and the stock works great with full ballast, extra surf ballast and ten people in the boat), but I imagine I will soon.2018 SAN G23 XR550
2015 SAN G23 XR550
2014 SAN G23 XR550
2013 SAN G23 XS550
2013 SAN G23 ZR450
2011 SAN 230
2010 SAN 230
2000 XStar
www.mnspringride.com
Originally posted by torchred04 View PostThe 2249 prop should be an upgrade on the 550hp G23's coming with the 2247 that has the 0.150 cup correct? Have you guys that run the 2313 and 2315 props noticed a nice difference with the drop in cup size? Looking for a spare prop for our 2247 stock prop.
Thanks2018 SAN G23 XR550
2015 SAN G23 XR550
2014 SAN G23 XR550
2013 SAN G23 XS550
2013 SAN G23 ZR450
2011 SAN 230
2010 SAN 230
2000 XStar
nyryan - Not sure if this would be in the cards for you, but if you'd be interested in trading your 2249 for either the 2313 or the 2315, let me know! Email is jlfogelson@hotmail.com.2018 SAN G23 XR550
2015 SAN G23 XR550
2014 SAN G23 XR550
2013 SAN G23 XS550
2013 SAN G23 ZR450
2011 SAN 230
2010 SAN 230
2000 XStar
- Feb 2010
- 921
- Phoenix AZ
IronJ which prop do you run currently?Eric, Phoenix AZ
2002 Super Air
I'm runnning the 2247.2018 SAN G23 XR550
2015 SAN G23 XR550
2014 SAN G23 XR550
2013 SAN G23 XS550
2013 SAN G23 ZR450
2011 SAN 230
2010 SAN 230
2000 XStar
Iron-I don't have it anymore...FYI I experienced 2 seconds faster to 2ph fully sac'd out by dropping cup from .150 to .105.
my reccomendation to you: send your prop to Nettles or one of the others and have them adjust your prop to 13 pitch and keep the .150 cup. $50.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
Originally posted by ironj32 View PostI'm runnning the 2247.
I was going to try that prop to see what ti does. Can you give me details on how it performs. Us up here at elevation are having a hard time deciding what the best prop is for the 550 engine. I have talked with ACME and they have proposed different props and i have been trying them out. the stock prop was the 1235 which slipped a lot so i didn't like it, the 2313 doesn't slip at all but has incredible hole shot so i am going to try the 2247 unless you think 2249 would be better. Let me know your thoughts thanks.
Tom- you are not going to achieve more hole shot by increasing pitch.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
