1996 Super (AIR) Sport Winter Upgrades - Wetsounds, Perfect Pass, LEDs, Decals Etc..
  • delmage171
    • 339
    • Ontario, Canada
    #31
    Originally posted by Brichter14 View Post
    When u did the cup holder mod did you re use the existing carpet? What cup holders did you use? Shallow ones? Any tips for people wanting to do this mod?
    I pulled the small shelve out from in behind the gunnel. I removed the existing carpet And removed the front vertical shelf support.
    I made cardboard templates to see where I wanted the holes drilled. I then drilled 2 5/8" holes and wrapped carpet around the shelves. Cupholders are deep ones from nautiqueparts.com
    1996 Super Sport Nautique
    2010 F150
    1989 Ski Nautique 2001 (sold)
    • Brichter14
      • Jun 2013
      • 531
      • Central Illinois
      #32
      Awesome one more question, what is that speaker wire covering you have in the pic of the tower fold joint? Are all the wires in the tower covered in that or just the section that leaves the tower? Did you drill in the footing of the tower for the speaker wire to exit?
      I really like everything you have done to your boat
      • delmage171
        • 339
        • Ontario, Canada
        #33
        That is this stuff right here.
        http://www.ebay.com/itm/Black-Braide...439c93&vxp=mtr
        I have that on the 2 front tower legs (where they bend forward) and also coming out of the tower up top into the Rev10s. I finished those off with rubber grommets. This was quite the pain in the butt, but I am super happy with how clean it turned out.
        Since I did not install the tower (the previous owner had 3 months before I bought the boat) I needed to get the 12gauge speaker wires down the tower leg and through the top gelcoat of the boat. I ended up drilled up through the fiberglass and tower footing.
        If I would have installed the tower I would have drilled a 1" hole in the centre tower footings before installing the tower and then drilled a 1/2" hole from the top down into the gelcoat to accomodate for the speaker/LED wires.
        hope this helps. I dont mind answering questions or providing photos
        2010 F150
        • Brichter14
          • Jun 2013
          • 531
          • Central Illinois
          #34
          Awesome! On eBay they had black,red, and black/red on that wire covering. Decisions decisions. They had it listed in metric not standard diameters. I'm kinda leaning toward red/black or all black.
          • delmage171
            • 339
            • Ontario, Canada
            #35
            Your boat looks sick! Nice trailer too!
            2010 F150
            • scarbs
              • Aug 2009
              • 450
              • Arizona
              • 2017 G23
              #36
              I then drilled 2 5/8" holes...
              2 5/8" or 3 5/8"?
              2017 G23
              2012 210 TE
              1999 SAN
              1995 Sport
              1991 Sport
              • delmage171
                • 339
                • Ontario, Canada
                #37
                2 5/8" or 3 5/8"?
                3 5/8"
                sorry about that!
                2010 F150
                • scarbs
                  • Aug 2009
                  • 450
                  • Arizona
                  • 2017 G23
                  #38
                  Thanks!!
                  2017 G23
                  2012 210 TE
                  1999 SAN
                  1995 Sport
                  1991 Sport
                  • s_kelley2000
                    • 1575
                    • Fort Meadow Recevoir
                    • Mass
                    #39
                    How does the installation of the water temp/depth gauge work? Did you have to drill a hole for a water sensor?
                    For the cupholders on the shelf, is it difficult to get bottles in and out of the two side cupholders? With the way that compartment is shaped I am wondering if I am better off going with two cupholders towards the middle where the compartment opening is the largest. If your setup is working well then maybe I will go with 3 like you did.
                    Shawn
                    2012 Blue Metal Flake SAN 230
                    • Pjoachim
                      • Apr 2013
                      • 124
                      • Wisconsin
                      • 2001 CB ski
                      #40
                      Nice work - looks like you spent a tremendous amount of time on the project...well spent.
                      Wisconsin
                      2001 196 Ski Nautique
                      2013 200V Team Edition
                      • delmage171
                        • 339
                        • Ontario, Canada
                        #41
                        Yes I had to drill 2 small holes for the mounting screws for the depth finder. It was simple. I believe you can buy thru hull glue on transducers though
                        The cupholders work great for holding beer cans or pop cans I mean. They can fit a Gatorade or water bottle too. I am happy with the 3 on each side. I think it looks pretty factory
                        2010 F150
                        • s_kelley2000
                          • 1575
                          • Mass
                          #42
                          Is the depth finder and water sensor the white thing on the transom next to the starboard pitot tube? If so looks easy enough. My current Hummingbird depth finder is still working but I would like to upgrade to the better looking Faria one with the temp sensor at some point once I get a few more things checked off my punch list.
                          Thanks for the cupholder info, that definitely looks factory and is a very nice addition. I will be copying your design except I think I will use stainless cupholders to match the ones I used for the four factory plastic ones I replaced.
                          Your boat is amazing, be proud of that thing!
                          Shawn
                          • delmage171
                            • 339
                            • Ontario, Canada
                            #43
                            The black thing is the transducer and the White attachment is the water temp sensor. The black transducer was installed over the spot where the starboard speedo sensor was . I removed that after adding Perfect Pass.
                            I wanted Stainless as well but $2.50 x 6 for new ones was cheaper then $14 x 10. I will probably upgrade to stainless someday!
                            2010 F150
                            • Brichter14
                              • Jun 2013
                              • 531
                              • Central Illinois
                              #44
                              how did you space them out evenly like that? I'm trying to do this mod now and the seat bottoms prevent the holders from being evenly spaced. Can u take a pic with the cushions out?
                              • jbach
                                • Aug 2012
                                • 187
                                • the state, not the jelly
                                • 1999 SAN
                                #45
                                bringing this to the top. what kind of wheels are those on the trailer? having a hard time finding some i like, those are sharp.
