Hi,
i have a 2010 230. At the moment i have the overflow ballast system, with 750lb bags in the lockers on top of tanks (replacing tanks and sacs with the 1100lb sacs this week sometime) and a 650lb bag under the seats at the front. we run a 1000lb nose cone on top of this using a tsunami pump. i am going to plumb the nose cone into the boat and was thinking overflowing from the V sac into the nose cone may be a little slow. has anyone had any experience adding an additional jabsco pump with the linc system? would it be possible to run 2 pumps off the same wiring and same intake hose? meaning when you hit the belly tank switch, both will fire up and fill the belly and nose at the same time? i want to do away with manual pumps all together. we bought 1100lb of lead which fits nicely in the esky compartment and opposite and takes up bugger all room. would be nice to just hit switches and ride. with no sacs in the middle of the boat. we would go more lead if it werent for the tow weight issue. Thanks in advance for any advice
