2008 210 surf wake help please
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    I garauntee you that is with NSS and the surf vert maxed out, the dead give away is how immediately steep it is behind the swim platform .... and the cheat to the surf side I describe with my NSS, you can see the lean in the video.
    FULL OEM ballast, 3 sacs ... the opposide side sac may have a little less than full, that is a pretty hard lean.
    1100 in the surfside trunk.
    Thats a nice looking wave.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • krt
      • Sep 2008
      • 231
      • La Verne
      • 2008 210 SAN TE
      I'm close to HS's recommendation, 1000 in the surf side rear locler, belly and overflow arrow bag plus 400lb bag in the front. We also have aprox 250lbs under the side seat (bag) and 200 lbs of lead weight we move around. Oh and about half a tank on the non-surf side in the rear. We adjust all this based on home many are on the boat. HG in the middle.
      2008 SAN 210 TE
      1997 Ski Brendella (sold)
      • iamcdn
        • Mar 2013
        • 337
        • Penticton, Canada
        • 2013 SANTE 210 with NSS
        I would assume it had the NSS since it is a 2013. It's even more impressive since it's the port side and I have had a harder time getting a clean wave on that side. I need a lot more weight in the bow (only have stock). Hope to test it out soon.
        • stjoe210
          • Jun 2013
          • 16
          • idaho
          • 2008 nautique 210 team
          so a 540 in the locker on top of the sock ballast, a 540 probably wouldn't fit on the seat behind the drivers seat though
          Originally posted by HS View Post
          I think for a 210, if a large wave is desired, you'd want 1,000 total on the aft corner, made up of factory or sac or both, and approx. another 1,000 in either the belly or the bow, combo of factory or sac or both. But if you have that much in people weight, you could get by with 540x2. Just my opinion.
