G23/25 warning placard removal
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    has anyone attempted removing all the warning placards all over their G yet? is it clean behind them or would their removal be ugly?
    1 massive big one on each tower base and another in addition to the USCG by the driver.
    I want to keep the standard Coast Gaurd placard.... but all those other ones look obnoxious, bright orange and yellow. just worried if I rip them off there will be a vinyle issue or an ugly hole behind them.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
  • santelee
    • Jun 2012
    • 162
    • tyler texas
    • 2013 G23 2008 SANTE 230-loved that boat
    in process of removing. got most of them off. the ones on base of tower really tough to get off even w adhesive remover.
    • santelee
      • Jun 2012
      • 162
      • tyler texas
      the ones on gel coat have nothing unsightly behind them nor does the tower
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        appreciate it... if all there is is adhesive behind the tower ones.... they are about to get pulled off. they are huge
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2007 Yamaha AR210
        • aarond0083
          • Aug 2006
          • 686
          • Triangle, NC
          Use a heat gun. I always removed the warning decals on my boats.
          Previous Nautiques
          2012 210
          2009 210
          2007 210
          2004 210
          • gate9869
            • Nov 2010
            • 153
            • Lawrenceburg in
            • 2009 super air nautique 230
            Did you just use a heat gun ? Was it a big pain in the A$$ ? I just got mine and I am thinking about removing them also.
            • Davidpsalt
              • Jan 2011
              • 92
              • Johns Creek, GA
              • 2018 GS22 2008 Ski Nautique 206 Limited Edition (Traded in) 1978 South
              Heat gun is the way to go - if you don't have a heat gun use a hair dryer on high. Doesent take much - use a plastic spatula to get under a corner then pull slowly towards the front of the decal if you are pulling from the rear. Avoid pulling straight out (90 degrees from the surface) as it will tend to leave the adhesive on the surface. Goof off used sparingly on a rag will clean off the residue adhesive.
              Thanks!
              Dave
              • nyryan2001
                • Mar 2013
                • 1993
                • Lake Anna
                The ones I'm targeting are the 3 separate obnoxious ones at the tower bases/ tower fold handle, the 2 extra ones by the driver (leaving the UsCg one) and the one up in the bow port side near the drink holders.
                2019 G23 450
                2014 G23 550
                2013 G23 450
                2007 Yamaha AR210
                • DealsGapCobra
                  • May 2010
                  • 375
                  • Knoxville, TN
                  • Ski Nautique 200
                  I don't own a G but did remove the decals from my 2010 200. The only issue I had were the ones stuck on the plastic 'chrome' interior. It looks like they ground the finish off of the part before applying the decal so it looked terrible behind. I was able to cover the ugliness with some fake 'carbon fiber' tape so it is OK. I ended up leaving the other stock sticker on the dash. Not sure if the G has similar interior trim but just wanted to share the info.
