neutral safety switch... normally open or normally closed?
  • shawndoggy
    • Aug 2011
    • 151
    • Reno
    • MB Sports TWB 23
    Can someone confirm to me how the neutral safety switch works? I want to use it as an automation trigger.
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    Pretty sure it's normally closed. When it opens, it shuts off.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • NCH2oSki
      • 1159
      • Maryville, TN
      • 2005 ski nautique 206 SE
      Normally closed.
      Prior Boats:
      1999 Ski Nautique GT-40
      www.skiersofknoxville.org
      • shawndoggy
        • Aug 2011
        • 151
        • Reno
        • MB Sports TWB 23
        awesome, thanks. How are the wires themselves connected to the switch? Will I need to cut a wire to pull a signal or is there a stud that i can put a second ring terminal on?
        • s_kelley2000
          • 1575
          • Fort Meadow Recevoir
          • Mass
          Out of curiosity what are you trying to automate? Something to do with stereo volume so it cuts way down when in neutral?
          Shawn
          2012 Blue Metal Flake SAN 230
          • shawndoggy
            • Aug 2011
            • 151
            • Reno
            • MB Sports TWB 23
            OK so I own an MB not a Nautique. But it's PCM powered and there's a lot more PCM knowledge here than anywhere else.
            I've installed a trim tab and I'd like to use the closed neutral switch as a trigger to redeploy the tab automatically. It would really be something like neutral switch + 15 seconds, so when I come off plane the tab deploys. I've already got the circuit set up (in my mind anyway!) for the tab to auto retract using an RPM window switch (for example auto retract at 3000 rpm).
            • surroundsound64
              • Jul 2005
              • 2147
              • Longview, TX
              Just splice into the wire.
              2018 SAN 230
              1981 Ski Nautique
              Sold - 2000 SAN
              • shawndoggy
                • Aug 2011
                • 151
                • Reno
                • MB Sports TWB 23
                Don't the two wires just connect to the switch with phillips head screws though? Wouldn't it make more sense to just put a wire on a ring terminal and put it on top of the existing wire and screw it back in?
                • surroundsound64
                  • Jul 2005
                  • 2147
                  • Longview, TX
                  I've never had one apart. I figured I was a micro switch with wires soldered on. If they are terminal connectors then yes but I don't think they are. Like I said, never had that area apart though.
                  2018 SAN 230
                  1981 Ski Nautique
                  Sold - 2000 SAN
                  • AirTool
                    • 4049
                    • Katy, Texas
                    http://www.skidim.com/prodinfo.asp?number=R153011
                    forgive me...tried the better site and couldn't find it.
