Help! Need trailer dimensions for SV211! ANYONE?!
  • jvjordan23
    • Jul 2012
    • 38
    • Ca
    • 211 Air Nautique
    I needed a new trailer for my 2005 Nautique 211. Found a great trailer that had a Tige RZ2 on it. Does anyone know what type of changes I will need to make for this boat to fit if any? I would love to know the dimensions of the trailer that has a 211 on it... It would really help! I can't believe how hard this is to find out. I have called the trailer companies and they say they dont know they use a machine. not very helpful. Thanks in advance!
  • Woody_tobius_jr
    • Dec 2012
    • 248
    • Alberta, Canada
    • 2004 SV211 Air Nautique TE
    What measurements would you like, my '04 is on a VIP t/a trailer. I can get some for you tonight or tomorrow
    • jvjordan23
      • Jul 2012
      • 38
      • Ca
      • 211 Air Nautique
      I need to know the distance between the two middle bunks and how far from those bunks to the outer bunks. and how long each bunk is… Also, the height from the bunk to the bottom of the trailer frame. If you can give me any of those measurements I would appreciate it! The trailer i bought the boat on was terrible. Thank you so much!!!! You have no idea how much help this is!
      • Woody_tobius_jr
        • Dec 2012
        • 248
        • Alberta, Canada
        I only have the single bunks, 38" inside and 49" outside ( this is going along the contour of the hull. The bunks are 11'-11" long. Now that I'm under there, it looks like I'm going to have to clean up the hull a bit.. It looks like the previous owners liked to beach the boat.
        Sorry I couldn't be of more help.
        • Woody_tobius_jr
          • Dec 2012
          • 248
          • Alberta, Canada
          Oh yeah, measurements from the bottom of the bunk to the top of the cross members ...it's 5-1/8" at the front bunk brace and goes to 7" at the second last bunk brace at the rear.
          • Rogue14
            • May 2010
            • 48
            • Southern Oregon
            • 2007 SV-211
            Here is what I have on my 2007 SV211:
            SB Trailer--don't know anything about them and have never seen anyone else on this board mention that trailer name.
            I have small 6" blocks cradling front of keel on center support leading from front of trailer to first crossmember.
            Front inner bunks: 3" from center of keel to inner side of bunk at front. Bunk is 55" long and 4 1/2" above front crossmember and 6" above middle crossmember.
            Long bunks begin at same place as inner bunks but are 14" from inner bunk to center of keel at front. It is about 130" long. It is 6"above front and middle crossmember and 8" above rear crossmember.
            Rear bunks are 23" from inner bunk to center of keel. This is 46" long. 6" above rear crossmember and 4 1/2" above rear frame of trailer.
              • 2908
              SBT - Sport Boat Trailer has been making trailers in Tracy California for many years and was one of the few to survive the 08-09 economy and remain in business without a reorg or name change. They make a nice product but watch the welds where the uprights connect the bunk support uprights to the cross members. This is where some have failed. My Zieman failed in the same place.
