Overflow fat sac setup
  • Nordicron
    • Sep 2009
    • 557
    • Madison, WI
    Originally posted by perry386 View Post
    Ok thanks guys. Can I get around adding an extra "safety hose" to the system by just watching the sac and making sure it doesn't go completely flat?
    Yes you could. Or once it gets sucked flat just open your red valve and your set.
    • TxJole
      • Jun 2009
      • 898
      • Cedar Creek Lake TEXAS
      Flat sack with no ability to vent equals this;
      • Nordicron
        • Sep 2009
        • 557
        • Madison, WI
        My port tank did that a couple times before I added my 1/4" breather tubes. Just bend that baby back straight an pound the tube back as round as possible with a hammer or use a vice so the float will slide freely and slap it back in.
        • Nordicron
          • Sep 2009
          • 557
          • Madison, WI
          I'll add that I think you only have the collapsing problem when running at speed and draining at the same time.
          • perry386
            • Jun 2012
            • 560
            • gadsden AL
            • Super Air nautique 236
            Yeah and we never do that. I think right now I'll just try and make sure there is air flowing through the sac.
            • TxJole
              • Jun 2009
              • 898
              #21
              That was about the third time for me too. You r right it is at speed. I have bending them back straight down to are art with split piece of steel pipe and a vice. Between the 3 210's we have in the family it's had a work out. Your 1/4 vents I copied have made my jig unless.
              • perry386
                • Jun 2012
                • 560
                • gadsden AL
                #22
                I just had a great idea to prevent bent sending units. Not anything we could do but something they should do from the factory. Why don't they put a stainless steel brace that goes from the bottom of the hard tank to the top of it inside the tank? This way the tank wouldn't suck in on itself and bend the sending unit.
                • HS
                  • Oct 2007
                  • 1333
                  • Sammamish, WA
                  • 2010 SANTE 210 (Sold)
                  #23
                  I bet it's because Nautique will not implicitly endorse adding ballast by providing a safeguard like that. As I recall the owner's manual urges folks not to do it.
                  • TxJole
                    • Jun 2009
                    • 898
                    #24
                    Plus overtime it would make a weak point in the tank from standing on them, weight of gear or sucking flat.
                    • perry386
                      • Jun 2012
                      • 560
                      • gadsden AL
                      #25
                      Well most other companies are doing it with plug and play systems. Oh well, just a thought. And the G23 has bags anyways so Nautique will probably stick with that route and do away with hard tanks completely.
