Originally posted by swankster
View Post
My buddy had a factory shower on his malibu which had closed cooling it was pretty much useless. I believe it picked up the water exiting the heat exchanger.
He ended up getting it to work but i think he had to put a heat exchanger to tap into the coolant to get the shower water to a warm temp.
Originally posted by shag View PostSo are there still contests for the give away's? Sure could use a heater for the 91 BF.....I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
My 1997 has a heatercraft heater in it. Still works well. If you're installing one know that the cores fail. My did and flooded the boat with 160 degree water. You can buy the heatercraft replacement core for $169 or go to NAPA and buy a 6603100 core for $40. The box needs some very slight modification to fit but works great. Do yourself a favor and instal a brass valve to be able to shut off water to it when it cracks. Its going to crack.
Originally posted by NautiqueJeff View PostI actually didn't get the hot side hooked up before the boat had to go to the new owner, unfortunately. Finding a hot source on the closed-cooled XS-550 proved difficult. Everywhere I tried to tap (even the heater lines) were anti-freeze! I never got a definite answer from PCM on the best place to tap, so instead of risk possible damage, I decided to let White Lake or the new owner of the boat tap into the hot side.
The cold side is easy enough though.
Originally posted by LakePowellMan View PostHas anyone found a good way to install a hot shower on a G23 w/ the 550? This is the last thread that I've been able to find on this topic. THanks so much.
oh boy....while I'd like a hot water shower...I don't think I want one that much. What a bummer! Thanks for the details.
I looked into adding a shower to my 210, which has a closed cooled 330, and I actually found a company in Australia that manufacturers heat exchangers for marine showers.
http://www.glind.com.au/store/heat-e...heat-exchanger
I haven't ordered it yet, because the engine bay is crowded enough with a 330 and the stock heat exchanger and I'm not sure if I want to make maintenance even harder than it already is.
I dont think that type of heat exchanger would be the best one to use, really all you need are some coils in a water tank... that type is designed for continuous flow (usually to remove heat from the hot side) so it would only increase the cold water temp by a small amount. the idea behind the water tank is that the cold water has a much longer time to heat up (like in a hot water tank).
Originally posted by pSchwade View PostI dont think that type of heat exchanger would be the best one to use, really all you need are some coils in a water tank... that type is designed for continuous flow (usually to remove heat from the hot side) so it would only increase the cold water temp by a small amount. the idea behind the water tank is that the cold water has a much longer time to heat up (like in a hot water tank).
https://en.m.wikipedia.org/wiki/Heat_exchanger
At the end of the day, the rate of heat transfer for continuous flow(how much your water temp will increase) is going to depend of the heat of your coolant/lake water, rate of your coolant/lake water flow, and the amount of surface area of the tubes containing the hot fluid. I'm not sure how many degrees this one can raise your water temp (maybe ask the manufacturer), but installing a hot water tank like you're talking about on an onboard tow boat is going to take up a lot of room. You can buy a marine hot water tank, even an electric one that saves you the trouble of running coolant, but I don't think you're going to want to give up that much storage space since they are mainly installed on cruisers.
This heat exchanger is designed to use a shower than pulls from an on board water storage tank which could be much warmer than the raw water temp that a ski boat would use. All I am saying is that you need a system that continuously heats a hot water reservoir and mixes it with the raw water to give a "warm" shower temp. Depending on the hot side temp you would probably only need a gallon or two to give you a couple of min run time.
