I'm looking to get another prop for my 2003 sante 210. I mainly wakeboard and wake surf. Wanting to get some of y'all perspective on what's a good size for what I wanna do.
I've heard really good things about the acme 1464 and 1578 (replaced the 1464 according to deltaprops). If you go to deltaprops, there is a coupon code form this forum.
w/ that prop, it will get on place really fast but sacrifices top end (so couldn't really barefoot if you do that occationally...)
The other one that has been recommended is the 644 -- but I don't know as much about it. From the sounds of it -- it doesn't sacrifice the top end quite as much, but has to work harder w/ a lot of ballast...
~Ben
If you are into hardcore Watetsports, and a 38mph wide open speed is OK... Acme 2315 period.2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
Just to clarify the OPs boat spins a RH prop and the 2315 and 1235 are both LH props. All Acme props will have even numbers for RH and odd for LH. The 644was the stock Team prop for that boat and is a good all around prop but the 1464 or 1234 will be much quicker out of the hole if you are running heavy ballast. The 1234 might cause some gel coat burn.Shawn
2012 Blue Metal Flake SAN 230
well in that case, look at the ACME 2078. same 14.5" dia size as a 1235/1234..... but pitched and cupped like a 2315. They dont even offer a 15" 2315 equiv for RH.
This will turn your boat into a F350 dually. I would like to see pics of prop burn.
If prop burn is of concern... by being only 1/4 closer to the hull, the most aggressive 14" prop is the 2132.... you'll likely be at 39ish WOT on that.2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
"touch under 1/2" of clearance"
I'd rather read about it than experience it though
Which part is the prop burn? the black marks??? thats where the rudder goes thru right? the prop would have been cenetered between those 2 squares right?2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
Originally posted by bsnively View PostI've just read about it -- but here is a pic I found on this forum:
