gel coat damage
  • chelms2206
    • Mar 2013
    • 24
    • Portland, TX
    • 2013 G23
    gel coat damage
    Anybody familiar with gel coat damage? Does it need to be taken care of immediately or is there some kinda of sealant you can put over it particularly because of it being the holiday weekend. Also do you know about how long the repair takes I'm sure its depending on the shop as well but just and estimate?
  • TRBenj
    • 1681
    • NWCT
    Its purely cosmetic if the damage does not extend through the glass below. Go skiing and fix it after the season.
    1990 Ski Nautique
    NWCT
    • azeus17
      • Feb 2008
      • 387
      • Grand Rapids, MI
      • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
      ^^^Exactly my thought
      • chelms2206
        • Mar 2013
        • 24
        • Portland, TX
        • 2013 G23
        Wil the fiberglass be a differeent color? i can see a texture difference but im not sure if its through the gel coat to the glass or not?
        • swc5150
          • 2240
          • Eau Claire, WI
          • MasterCraft Prostar
          At least on my monitor, it looks likes the large spot is down to the glass. If it were me, I'd run down to the local marina and grab a gel coat repair kit to cover it up temporarilly - until I could get it into the glass repair shop. I tend to be a little over-cautious though.
          '08 196LE (previous)
          '07 196LE (previous)
          2 - '06 196SE's (previous)
          • TxJole
            • Jun 2009
            • 898
            • Cedar Creek Lake TEXAS
            I would put some suncure on it till the off season. I see glass.
            • chelms2206
              • Mar 2013
              • 24
              • Portland, TX
              • 2013 G23
              Alright thanks thats what i needed to know! The gel coat repair fairly easy to use?
              • jbach
                • Aug 2012
                • 187
                • the state, not the jelly
                • 1999 SAN
                http://www.spectrumcolor.com/Index.aspx?key=cat
                call these guys. they make kits for almost all colors of most manufacturers.
                • swc5150
                  • 2240
                  • Eau Claire, WI
                  It's easy... You may do such a good job that you won't bring it in for repair. I suppose it depends if you want a patch job or give the full repair a shot yourself?
                  • Toothstud
                    • Sep 2012
                    • 21
                    • San Antonio, TX
                    West Marine DIY gel coat repair video
                    • AirTool
                      • 4049
                      • Katy, Texas
                      AND, of course, ....we are NOT going to ASK how it happened.
                      • swankster
                        • Aug 2010
                        • 1052
                        • DFW, TX
                        Yeah, Like if we knew maybe we could avoid the same issue too. I may not sleep tonight worrying about it.
                        2010 SANTE 230 343 (280hrs)
                        • TRBenj
                          • 1681
                          • NWCT
                          Being able to see the glass doesnt mean jack.
                          The glass has to be *damaged* for there to be any concern at all. Gel is purely cosmetic. If the glass isnt damaged, even if visible, just run it.
                          You can fix it properly now if you want, but running it as is will not cause a problem. Putting a temporary repair on it for no reason will just make the doing the proper fix later more of a PITA.
                          1990 Ski Nautique
                          NWCT
                          • chelms2206
                            • Mar 2013
                            • 24
                            • Portland, TX
                            • 2013 G23
                            Im not sure if it happened hitting debris in the Ohio river while riding or while putting it on the trailer during the 20 mph current we were having (current speed is an exaggeration). All the rain we've gotten has the river trashed right now. Thank yall for the advice though i appreciate it.
                            • AirTool
                              • 4049
                              • Katy, Texas
                              Im not sure if it happened hitting debris in the Ohio river while riding or ......
                              The Ohio river is a LOOOONGGG way from 78374.
                              Whassup with that?
