Ok need more help
Problems turning over motor to start. Punch in the keycode and push start, loud "click" as if its about to turn over then dead. Dash is even blank. Re enter dash code, start & same thing...
Battery fully charged, installed new starter and went to test it. Same thing!
Motor turns over just fine when I put screwdriver across starting relay in engine compartment
No fuses or breakers are popped. Battery load tests great. Terminals are all tight on new starter
Ill swap out relay tomorrow but just seems kinda odd. Any ideas out there on what else to check??
