I was going to swap out the hard tanks in my '01 SAN, and put in the 750's.
I would really like to get rid of the need to constantly open and close the valve in the engine bay area as well. I know by switching to jabsco pumps, this can be achieved, but was thinking of doing a different short term solution -- if it would work well.
I was thinking that I would put in a check valve on the current fill/drain hose -- and make that a dedicated fill line that get plumbed to the 750's (eventually making it use two pumps, but for now -- use the single pump to fill both bags).
each bag would then have a dedicated pump on it that went out the current vent hole. I like this because it gives a nice indication of when the bags are empty (since the sensors won't work on the dash/etc).
My question is if I need a dedicated overfill/vent plumbing in addition to the drain plumbing. The drain pump will be attached to the bottom of the bag -- and I was assuming that if the bag was full -- the water would be pushed through the drain pump and out the current vent hole. This would make the install much simpler rather than putting a T on the on the current through-hull fitting near the rub rail and having to install more check valves.
Will that work well -- or do you think I need to add the extra pieces/etc?
Thanks,
Ben
Thanks,
Ben
