Does anyone have a pic of where the depth finder is mounted on an 03-06 210? I know it's in the bilge, but my 210 appears to not have one and if it doesnt then I'm going to try to mount it in the factory location.
Most people mount them in the dash so you can read depth while driving the boat. If you put it in the bilge that would be a pain to use.
Ok I kid. On my 97 SS it's right in the middle off to the port side in between e v drive and engine. Probably want to mount the transducer as middle of the hull as possible to get an accurate reading.
Originally posted by Brichter14 View PostMost people mount them in the dash so you can read depth while driving the boat. If you put it in the bilge that would be a pain to use.
Ok I kid. On my 97 SS it's right in the middle off to the port side in between e v drive and engine. Probably want to mount the transducer as middle of the hull as possible to get an accurate reading.Jason
All black 2003 SANTE
-- Southern Fried --
Yeah, I'm getting no reading when I switch the gauge to the depth finder mode and it doesn't look like its hooked up to the gateway box. I'm hoping its still there and just needs to be reconnected, but if not I can just order a new one and mount it in the original location. I've drilled through gelcoat before, but I'm still holding out hope that I'm blind and somehow missed it when I was looking.
Thanks!
