G23 Ballast Pump Circuit Warning
  • ttagliareni
    • Jul 2013
    • 11
    • Sanford, FL
    • 2013 G23
    I took possesion of my G23 on July 3rd of this year. The boat recently displayed a warning message regarding the starboard ballast pump circuit. Since that message was displayed my G23 has started taking on ballast in all three tanks without any input from me. I don't know what triggers the pumps to start taking on ballast, it just happens at various intervals.
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Auto presets?
    You said in the other thread you used the pro wakeboard presets... select them, your ballast will auto fill.
    i had that error thrown once... I cleared it, never came back. It came on after I have been running my pumps for nearly 15mins. OEM tanks + 1100 piggys.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • ttagliareni
      • Jul 2013
      • 11
      • Sanford, FL
      • 2013 G23
      I'm in Back to Dock mode when the ballast starts to fill on its own, so I don't think that's it, unless I'm missing your point.
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        Back to Dock mode = pumps auto drain on their own.
        I know you hear the pumps running... but they should draining not filling. Are you sure they are filling and not drianing? If you select back to dock, everything will auto -drain.
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2007 Yamaha AR210
        • ers906
          • Feb 2010
          • 921
          • Phoenix AZ
          That code tends to get triggered if you stop your pumps by hitting the opposite button (empty to stop filling of that makes sense). I would clear the codes and reset to manufacturer settings, then custize to ur pref again. Do that when the boat is on the trailer or lift to ensure the ballasts are completely empty
          Eric, Phoenix AZ
          G23 550 hp (finally here)
          2002 Super Air
