Originally posted by dlowry81
View Post
My second prop shaft failure happened yesterday. First was on our 17 G23 and this time on the 18 G23 with mid-30s hours. We were heading home going maybe 20 mph with no ballast and four in the boat. Thankfully my buddy (also with 18 G23) was nearby to come assist, but we laughed about his shaft breaking while towing!
My dealer said his customers' failure rate was around 75% this year. They provided great service by overnighting the new shaft and will have us back on the water within 48 hours. Hope CC can get to the bottom of it soon.
Originally posted by heel5man View PostMy second prop shaft failure happened yesterday. First was on our 17 G23 and this time on the 18 G23 with mid-30s hours. We were heading home going maybe 20 mph with no ballast and four in the boat. Thankfully my buddy (also with 18 G23) was nearby to come assist, but we laughed about his shaft breaking while towing!
For those have issues in the 18's, which engines are you running. How about the dealer with 75% failure rate...they mostly the H6 or XR7? Also, do you know if your shaft key slot is/was shorter than what they used to be?
I noticed that my key slot is much shorter on mine this year, not extending back to the strut, unlike a friend who has a 2017 G23. I wonder if that is in effort to remediate the problem?2018 SAN G23 XR550
2015 SAN G23 XR550
2014 SAN G23 XR550
2013 SAN G23 XS550
2013 SAN G23 ZR450
2011 SAN 230
2010 SAN 230
2000 XStar
www.mnspringride.com
One thing I thought was interesting... I asked him if he ever had to do a second repair on the same boat. He said so far, no, and he’s been dealing with this issue for 4-5 years. That is really puzzling to me. It would seem like the failure rate on the replacement prop would be the same unless the parts were different.
Interesting point about no failures on the same boat twice. Also someone else observed that it seems if you get beyond 100 hours, your risk of shaft breaking goes way down.
Is Nautique the only boat mfg to use the key with a dimple? They have done this since 1997, but I wonder if this weakens the shaft to the point a 17 inch prop can then break it. Until I picked up a spare today, I had never seen one with that dimple (I've not yet swapped my own prop out).
Just saw a new G25 delivered to one of my neighbors and wondered why since he got a new G23 last year. In turns out he had 3 prop shaft failures in a year. I even overheard employees at the gas dock talking about this issue.
Wow, I am surprised that this is still happening. I love my Nautiques but nothing is perfect and this is clearly an engineering failure. At some point these boats are going to need larger shaft diameters, new struts, couplers and the props to handle the force exerted. Big undertaking for CC but it can't be cheap replacing all these shafts and props not to mention keeping new boat owners off the water.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
For those of you that have lost a prop can you recall anything hours or days in advance of the failure that may have been a warning sign? (Audible or physical via the hull or controls)
Also, those that have had the failure...were you primarily surfing and what was your production month/year?
We travel long distances on our lake and I am in fear of this failure happening when we are out of the country (lake is in US and Canada) with no towing services...just have to hope a friend or neighbor is around for the rescue.
We are at 50 hours with a production date of 02/18. G23
Originally posted by ST3 View PostFor those of you that have lost a prop can you recall anything hours or days in advance of the failure that may have been a warning sign? (Audible or physical via the hull or controls)
There seems to be little correlation between surfing, wakeboarding, year-model, or hours. There are plenty of Gen 1 2013 G23s on the first drive shaft. My neighbor's is. He has over 750 hours on that boat. There are some people on their third drive shaft. It seems to be incredibly difficult to predict.
-Charles
When your prop decides to exit, being there is no load, does the engine race to redline or is there safe guards that prevent valvetrain damage? I would assume the engine cuts fuel or spark if max RPM is reached.
The engines are rev limited.
As for inspections I seriously doubt that you will see any cracks prior to the breakage. Microscopically maybe, visually no.
The shafts are too close to strength limits and the result is failures. Either larger shaft diameters or a change in metallurgy is the answer.
Great that these are being taken care of quickly under warranty but what happens when the warranty expires? This could be a 1K hit plus time off water. Resale value?2018 200 Team H6
1987 ProStar 190
