G23 Prop Fell Off .....
  • SoCal G-Man
    • Apr 2016
    • 329
    • Westlake Village
    • 2019 Super Air Nautique G23
    #496
    Originally posted by cptotr View Post
    Here are the pics from when mine broke
    Sorry to hear another G23 member joining our prop shaft club. Check inside your hull. When mine broke, it looked minor from underneath the boat like yours, but it had punched a hole through.
    • cptotr
      • Jul 2018
      • 53
      • Jackson, MO
      #497
      I should probably look that hull over a little closer when I get back to the boat. Let me know what you find out on the props and if it does or doesn't have a longer hub and even if it matters. It doesn't seem like it could make a difference, but I'd definitely be interested if it did. I wonder if the dealer would put something else other than what came on it stock for the warranty repair??
      • scarbs
        • Aug 2009
        • 450
        • Arizona
        • 2017 G23
        #498
        Originally posted by SoCal G-Man View Post
        Thank you. The ACME sales rep explained to me that a longer hub would reduce the chance of a shaft breaking. I just looked on their website, and the 3345 and 3081 seem to be identical. Perhaps ACME has their specs wrong online and their sales rep has it backwards? I just left a message for Brian at Valley Prop Service in Ventura, CA. He has been a prop guru for decades. Hopefully he can shed some light on this, and I can share his opinion.
        I just went through this with Nautique and ACME. I had the 3081 on my boat when the main seal on the transmission failed and leaked all of the fluid out. We had no idea until it was too late and the transmission completely failed leaving us stranded for hours at Lake Powell. Everything was covered under warranty, but as part of the repair, Nautique agreed to preemptively change the prop shaft and prop. As part of that repair, the dealer claimed that the larger hub of the 3081 was rubbing on the strut and "may" have contributed to the transmission seal failure and refused to reinstall the 3081 on the boat--even though it had installed the 3081 on the boat in the first place. I talked to ACME about it and it refused to believe the dealer's theory, but fortunately, ACME agreed to swap out the 3081 for a 3345. I currently have both the 3081 and 3345 props in my possession as well as two stock props and can confirm that the 3081 has a bigger hub and that the 3345 has a hub identical to the stock hub. But I have no idea which one is better for the breaking shafts. Seems like the stock props are breaking the shafts at a higher rate than any other prop.
        2017 G23
        2012 210 TE
        1999 SAN
        1995 Sport
        1991 Sport
        • SoCal G-Man
          • Apr 2016
          • 329
          • Westlake Village
          #499
          I am sure there are several theories about rotating mass behind the strut. It seems like spreading-out the prop weight would be less stress on the driveline, unless the additional weight of the 3/8" longer hub causes more driveline stress? I should have paid more attention in math...
          • SoCal G-Man
            • Apr 2016
            • 329
            • Westlake Village
            #500
            I don't see how the additional 3/8" can come close to rubbing??? At least on my 2016.
            • scarbs
              • Aug 2009
              • 450
              • Arizona
              • 2017 G23
              #501
              I was skeptical, and thoroughly questioned the dealership about it. It ultimately admitted that the prop sat approximately 1/8"-3/16" away from the strut. And further admitted that it was their theory that because it was that close to the strut, the pressure created in that small space "may" have caused problems. Neither I nor ACME believed this theory, but the dealer would not put the 3081 prop back on. I have no idea who is right or wrong--just that I now have the 3345 on the boat instead of the 3081. Interestingly, the two are supposed to have the same specs, but RPM on the 3345 at surfing speed are about 150-200 higher than the 3081 (still about 300-350 lower than the stock prop).
              2017 G23
              2012 210 TE
              1999 SAN
              1995 Sport
              1991 Sport
              • SoCal G-Man
                • Apr 2016
                • 329
                • Westlake Village
                #502
                Wow, that is interesting. Thanks for sharing.
                • <ReLax>
                  • Sep 2018
                  • 11
                  • Atlanta
                  • 2019 G25
                  #503
                  I have a new 2019 G25 and just stumbled across this thread. Are these prop issues happening with the G25s too or limited to the G23s?
                  • NautiqueJeff
                    A d m i n i s t r a t o r
                    • Mar 2002
                    • 16554
                    • Lake Norman
                    • Mooresville, NC
                    #504
                    I actually can't remember ever hearing of a G25 with a broken shaft. There have been multiple other G-series (G23 and G21) boats with this failure, but I don't remember ever hearing of anyone with a G25 with this issue. I could be wrong though.
                    • GMLIII
                      • May 2013
                      • 2797
                      #505
                      You probably almost fainted when you found this thread . I think about my prop shaft breaking ever time I go out in my G23
                      • RDT-G23
                        • Jun 2017
                        • 589
                        • TEXAS
                        • 2020 G23 PARAGON I 2017 G23(sold)
                        #506
                        As do I... This shouldn't be the case.
                        • charlesml3
                          • Jan 2008
                          • 2455
                          • Lake Gaston, NC
                          • 2022 G23
                          #507
                          I've never heard of a 200, 210, 230 or any GS boat with this issue either. Weird how it seems to be completely limited to the G21 and G23.
                          -Charles
                          • Kenv
                            • Jan 2004
                            • 1070
                            • Texas
                            #508
                            On this thread....Post number 59......G25. I think that's the only one I remember...and it's only been about 6 G21s....maybe a few more.
                            • GMLIII
                              • May 2013
                              • 2797
                              #509
                              It would be interesting to know by a company insider on the total breakage count by model and year
                              • Kenv
                                • Jan 2004
                                • 1070
                                • Texas
                                #510
                                For sure GMLIII. That would be a Golden ticket right there. If I had to guess....I'd say 40 G23's....10 G21's....and 5 G25's of various model years...from 2013 to 2018. Also curious about any boats outside the U.S.....and if any were Coastal Edition with the James Bond submarine attack spinner feature.
