G23 Prop Fell Off .....
  • jrz1
    • Jan 2013
    • 215
    • Lake Norman, NC
    • 2013 G25 XS 550
    #46
    Could be that dealers would rather be quiet about it unless they had a customer who experienced the problem.
    • robertsmcfarland
      • Oct 2004
      • 544
      • Hyco
      • 2014 g23 550
      #47
      what month and year was your g23 built? I wounder if there is any collation between dates shafts were bought and installed? sorry about your break down , hope CC gets you back on the water quick!!!!
      2013 G23 super air
      2010 230 super air
      2009 220 super air
      2008 210 super air
      2005 210 super air
      2003 calabria pro air
      • AllianceBJJ
        • Jun 2009
        • 347
        • Cedar Hill, Texas - Joe Pool Lake (Lynn Creek Marina)
        • 2013 G23 2012 SANTE 230 2011 SANTE 230 2010 SANTE 210 2006 SANTE 210
        #48
        If there is a failure, you are likely losing a prop and having gel work redone. This is easily a couple of thousand dollars on top of the warranty claim for the shaft (trust me I have had to have gel work before). Nautique isn't in the business of spending money for no good reason or gambling that something won't happen. A large recall would be out there and people would be called to bring there boats in. I can't imagine the PR/customer relations nightmare that would hit if a bunch of shafts were known to be bad, broke and they did nothing. Nautique would likely have those dealers for lunch...Also, how many people would re-think there next boat purchase if the dealer didnt do something for there $120K+ boat and they got stranded and left without a boat for part of the season? I know I would.
        Not to say this stuff hasn't happened sporadically around the country, but I'll trust Phil on this one so far. He has a lot of G boats in the water and would be all over this to protect his customers. Every little thing (mirror clamp, tower braces, rudder, etc.) that has been a recall on my last 4 Nautiques has been done as soon as the recall came out.
        Current Nautique: 2013 G23
        Previous Nautiques: 2012 SANTE 230, 2011 SANTE 230, 2010 SANTE 210, 2006 SANTE 210
        • schaabj
          • Oct 2011
          • 140
          • Canada
          • 2013 Super Air G23
          #49
          I asked my dealer about this issue and they informed me there was a bulletin out on this where dealers are advised to check the length of the piece protruding from the hull which holds the prop shaft. It is supposed to be a certain length and I guess if it is wrong it will be too short from my understanding.
          My boat will be going in beginning of May for warranty work and NSS so they will be checking mine then.
          • AllianceBJJ
            • Jun 2009
            • 347
            #50
            Forwarded this to Phil as well....We'll see if there is a response...bulletin vs. recall is where I am sure this whole thing is going....hopefully dealer's saying no prob aren't blowing smoke...seems silly to be playing with fire if you are a dealer and not informing people of this....a lot on the line...
            • AllianceBJJ
              • Jun 2009
              • 347
              #51
              Apparently bulletin is for a limited number of boats w the 550....
              • schaabj
                • Oct 2011
                • 140
                • Canada
                #52
                Greeeaaaaatttttt
                • biggator
                  • Sep 2012
                  • 208
                  • lake lanier
                  • G23
                  #53
                  Interesting.. lion and I have 450s.. I wonder if that's why our dealer wasn't concerned.?
                  • lion90
                    • Apr 2009
                    • 182
                    #54
                    Our deal confirmed that my hull (and likely yours) were not part of the service bulletin.
                    • Tabiggs
                      • Apr 2013
                      • 31
                      • Houston and Austin
                      • 2013 G25
                      #55
                      My G25 was delivered last October 2012, I think I ordered in in late Aug so it had to be some of the first ones produced,
                      Based on the posts here, it does not sound like the 450 is involved, since there is no 'bulliton or recall' for the 450 based on the diameter of the shat. It was expalined to me the the shaft extends down from the housing type area is 'milled down' from the original diameter, in other words, the shaft is thicker inside the housing area, and they are breaking where the the starts to taper down in thickness. or is breaking in the area where it extends down to the prop
                      - I am going to guess that the shaft is the same as the 450 and 550, does anyone know?
                      Everyone knows that the dealers are all about service when buying a Nautique, and it sounds like some of the first ones with the 550 had these issues and upon realizing the problem, immediately made modifications on the newer 550's. Once the shafts are replaced, I suspect the problem and posts will go away.
                      • nyryan2001
                        • Mar 2013
                        • 1993
                        • Lake Anna
                        #56
                        Holy Crap. Sorry to hear about that.... 550 or 450 motor??
                        2019 G23 450
                        2014 G23 550
                        2013 G23 450
                        2011 Malibu Wakesetter 247
                        2007 Yamaha AR210
                        • ironj32
                          • May 2011
                          • 601
                          • 2018 SAN G23 XR550
                          #57
                          Sorry to hear about that. Hopefully they fix it asap for you!
                          2018 SAN G23 XR550
                          2015 SAN G23 XR550
                          2014 SAN G23 XR550
                          2013 SAN G23 XS550
                          2013 SAN G23 ZR450
                          2011 SAN 230
                          2010 SAN 230
                          2000 XStar
                          www.mnspringride.com
                          • s_kelley2000
                            • 1575
                            • Fort Meadow Recevoir
                            • Mass
                            #58
                            Sorry to hear this! Glad you got back safe and didn't get stranded in the middle of a big lake. Hopefully you can get it back on the water quickly.
                            As for the shaft size, I know CC has been using 1 1/8" shafts on their v-drives since at least the mid 90's. If the service bulletin was to put a thicker shaft on then it sounds like your dealer was not being very truthful. I think there might have been some information about shaft thickness in the Yeargin interview on the main page.
                            Shawn
                            2012 Blue Metal Flake SAN 230
                            • schaabj
                              • Oct 2011
                              • 140
                              • Canada
                              #59
                              XS550 Engine
                              • Chexi
                                • Apr 2025
                                • 2119
                                • Austin
                                • 2000 SAN
                                #60
                                Wow, sheared right off. This is a huge issue.
                                Now
                                2000 SAN
                                Previously
                                1999 Air Nautique
                                1996 Tige Pre-2000
