Originally posted by SoCal G-Man
View Post
Originally posted by Kenv View Post
Let's just say I'm taking a ballpark guess from the ones I've counted on here....the ones my 2 dealer locations in Texas told me about and my one friend it personally happened to. I'd solidly say that number is about 30. I am not saying I am anywhere close to a worldwide count .....but would be curious to know the actual number.
Let's just say I'm taking a ballpark guess from the ones I've counted on here....the ones my 2 dealer locations in Texas told me about and my one friend it personally happened to. I'd solidly say that number is about 30. I am not saying I am anywhere close to a worldwide count .....but would be curious to know the actual number.2019 SAN G23 | 2016 SAN G23 | 2013 Wakesetter 23 LSV | 2008 Wakesetter 23 LSV | 2003 Wakesetter 23 LSV | 2000 Wakesetter VLX | 1998 Sanger V210 | 1994 Magic Sceptor 28 | 1985 Cole TR2 | Too many PWC to count!
Originally posted by SoCal G-Man View Post
Are you saying 30-40 on this forum? From my experience, very few G-series owners are members on this forum.
As far as the comments about very few G23 owners frequenting this forum...I suspect when an owner does have a prop shaft fail a very high percentage of the affected owners come to learn and post about it in the forum.
So if a high percentage of affected owners post here but a low percentage of all G owners show up, it would argue for the percentage of total failures to be lower than most here are estimating.
yeah, i kind of doubt it.
Sent from my SM-G965U using Tapatalk
I don't think we know how many people will do a "google search" when their shaft breaks. That is my opinion.
But you state that "dozens of others who had this experience have done". Cite your references. Supply the names and proof of those that google searched after their shaft broke, or admit you are just guessing. I admit I am just guessing. Please do the same.
Dozens...Surely you jest. Two dozen. Three dozen. How many dozen are you referring to? How many people do you really know that broke a shaft and then google searched?
Admit it is idle conversation...
Originally posted by scottb7 View PostI don't think we know how many people will do a "google search" when their shaft breaks. That is my opinion.
Admit it is idle conversation...Last edited by greggmck; 10-30-2018, 09:32 PM.
Exactly. I'm with you Greg. Technically "dozens" to me is 24 or more...more than 1 dozen......and I skimmed that in 10 minutes. And SO WHAT if they are on here or not....they will be or have been counted somehow in the big picture when this is all said and done. Grand kids will be telling stories about the time their Papa's shaft and prop broke. We got to get towed home!!! Yay......
I found my prop to be just a little bit loose today while checking everything out. After 350 hours, it seems a little strange. It fell off without a puller. I would just throw that out there and wonder if a busted shaft was going to happen next. If the tapers don't match up perfectly, then busted shafts happen.
How often do you guys check your prop nuts? I don't think I have checked it in quite a while. I suspect it is on the list for the 300 hour service, but my dealer likely did not adhere to any specific list.
Originally posted by Tallredrider View PostI found my prop to be just a little bit loose today while checking everything out. After 350 hours, it seems a little strange. It fell off without a puller. I would just throw that out there and wonder if a busted shaft was going to happen next. If the tapers don't match up perfectly, then busted shafts happen.
How often do you guys check your prop nuts? I don't think I have checked it in quite a while. I suspect it is on the list for the 300 hour service, but my dealer likely did not adhere to any specific list.Last edited by GMLIII; 11-21-2018, 05:27 PM.
Was your prop nut loose prior to removing it when the prop just slid of the shaft?
Let's see if this works, I video'd it a little bit: I am not sure if everyone can see it or just me.
https://photos.app.goo.gl/Ap2Fva8ZA6j9pFJM7Last edited by Tallredrider; 11-21-2018, 05:08 PM.
It was a tiny bit loose, causing the slop. It just seems unusual for the nut to back off. FAIK, the dealer had to have an urgent prop replacement for another customer's boat and took mine and didn't put it back solidly. I suspect this would have eventually caused a problem, if it was going on for 350 hours.
The nut most likely did not back off- the prop seated deeper from the force pushing the boat. Bet the dealer just slaps the prop on,does not bother to seat it properly. Here is a good pictorial on how to do it,3rd block down is interestingLast edited by gary s; 11-29-2018, 03:46 PM.
