speedo problem
  • bfinley1977
    • Mar 2005
    • 41
    speedo problem
    can anyone tell me what to check when your speedos are not working. 97 sport nautique. also the depth finder works sometimes and other time is doesnt come on.
  • bkhallpass
    • 1407
    • Discovery Bay, CA
    With the speedos on your boat, my experience was that 99 out
    10 times, something was stuck in the pitot, or something
    was blocking the tube between the pitot and speedo guage.
    You can use a needle to make sure the hole in the pitot is not clogged.
    You can disconnect the tube at the speedo guage and pitot, and blow air
    back through it.
    BKH
    2001 Super Air
    • bfinley1977
      • Mar 2005
      • 41
      thanks for the input you have any suggestions about the depth finder?
      • bkhallpass
        • 1407
        • Discovery Bay, CA
        Wish I did. I had a 98SN, and I now have a 01 SAN. On each
        I have experienced periods where the depth finder goes out for no apparent reason.
        Happens more often when I'm in the delta or shallow rivers, less often
        in deep lakes. It always comes back, so I've never worried about it.
        I'll be interested to see what feedback you get from others on this
        site. Maybe I'll "fix" my depth finder once you uncover the secret.
        BKH
        2001 Super Air
        • bfinley1977
          • Mar 2005
          • 41
          that is exactly what mine does it works in deep water or when i am going really slow in not so deep water teh shallow water is were i need it not 97 feet deep open water.
          • raygunclan
            • 325
            • close enough to the lake to be able to run in and grab a beer, but far enough not to pay the taxes!!
            i can't believe nobody has thrown this one at you, but (and i'm sorry, but i just can't pass up the opportunity!)
            maybe you shouldn't wear a speedo if it isn't working for you!
            Yellow_Flash_Colorz:
            • bfinley1977
              • Mar 2005
              • 41
              yeah that is what my girlfriend tells me. i figured if i wore one then the one on the boat would start working
              • ag4ever
                • 1180
                Depth finders are not that accurate or reliable in muddy bottom lakes/rivers.
                Nothing for the sonar to bounce off of reliably, so the water can cause irregularities.
                Just slow down, and allow the sonar to start working again. 9Kinda sucks when pulling somebody though)
                • bfinley1977
                  • Mar 2005
                  • 41
                  does anyone know were the sensor for the depth finder is located?
                  • CHassmann
                    • Jul 2004
                    • 513
                    • Holiday Lakes, OH
                    Look in your bilge, possibly near the bilge pump.
                    Ski on dude!
                    • bkhallpass
                      • 1407
                      • Discovery Bay, CA
                      Yes, should be in the bilge area. Probably at or near the transmission.
                      Should be glued to the fiberglass floor.
                      BKH
                      2001 Super Air
                      • raygunclan
                        • 325
                        bf
                        a friend of ours, who is a well known local architect, went snow skiing with one of his clients and a group of his client's friends, girlfriends and wives, none of which he knew. the first night, as a joke, he jumped in the hot tub with all of them in a yellow thong! every time i think of that story i get the giggles!
                        • jasper
                          • Feb 2005
                          • 195
                          My depth finder has a mind of its own. Most of the time it reads 2.7 ft. Once in a while if you treat it just right, it will actually tell you the correct depth for at least a few minutes. I called Teleflex(?) to inquire. They informed me that product was sold to Hummingbird. I called Hummingbird. They informed me that, unfortunately, the odd behavior was a sign of the unit going out. The best fix was to replace the unit - $99.00.
                          • bfinley1977
                            • Mar 2005
                            • 41
                            raygunclan: thanks for the mental picture of that hot tub scene lol
                            and to everyone else thanks for the input it has been a big help
