Not sure if anyone else has been curious to know how the two compare, but I know I was. Finally got out today in a new 450, with the 2:1 tranny and 17" prop. I found that the new setup of the 450 can handle about 400 more pounds than the previous model, and gets to speed quicker as well. As for how it stacks up against the 550...not even close. I loaded up the 2014 450 with the same ballast setup I run in my 2013 550. After a couple of different tries, we ultimately had to empty out about 800-1000 pounds. You could definitely tell in the size of the wake (don't get me wrong, it's still bigger than everything else out there, that I've been in). I took note of where bottom of the G23 emblem was as compared to where mine is to the water line...the 450 is about 6" higher out of the water.
Hopefully this helps those who had the same question as I.
