The G21 is Here!
  • Nautiquehunter
    • Jun 2008
    • 2080
    #76
    It looks like the highest point is at the windshield. You could use a drop ball mount to easily overcome 3''. This one moves 9'' this is a 269.95 problem or just but the other boat that's not as good but stores well?
    [Tow & Stow Class IV Ball Mount - 9" Drop - 9 1/2" Rise - 2" x 1 7/8" x 2 5/16" Hitch Balls
    $269.95
    • jonsquatch
      • Jul 2012
      • 251
      • AZ
      • 2012 Super Air Nautique Byerly Icon
      #77
      $269.95
      Thats exactly what I was thinking, I use an XD hitch on my Suburban anyway since they have a removable mudflap that just clips on if you got the 10" version you could back it in to just shy of the windshield and then take the weight with the jack and then pull the pin and drop it all the way down. Wouldn't go as far as the caster but might get close enough and still be able to just back it in instead of push.
      http://inventiveproductsinc.com/FW_ITD9212.php
      2012 Super Air Nautique 210 Byerly Icon Edition EX343 <-- Current Boat
      2007 Reinell 185 BR Volvo Penta 4.3GL <-- Former Boat
      1988 Bayliner 195 Capri OMC Cobra 5.0 <-- Former "starter" Boat
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        #78
        Or pick up a one HP motor at harbor freight and built a small push dolly (online diagrams can be found). I have a commercial airline one, but the height would likely be too much for what we are looking for. It has a one hp motor and works great.
        Eric, Phoenix AZ
        G23 550 hp (finally here)
        2002 Super Air
        • ers906
          • Feb 2010
          • 921
          • Phoenix AZ
          #79
          DC and Jon, I think we need to convince Robbie to let us ride behind one for the day when the first comes in. If the wake is as close to the 210s shape, it may change my mind about switching from the G23. I think at the Xmas party his mind should be pliable enough
          Eric, Phoenix AZ
          2002 Super Air
          • xrichard
            • Aug 2008
            • 669
            • El Dorado Hills
            • 2023 G23
            #80
            Thanks for posting the spec sheet, Jeff.
            Looks like the total height of the boat not including trailer is 7' 1" with tower folded, so there might be opportunity to work with a trailer manufacturer to keep on-trailer clearance just below 8'. It could be the 8'6" max trailer width (most states) forces the boat to sit higher on the trailer than otherwise necessary.
            Also...I see the trailer weighs 1900lbs. I didn't realize trailers were that heavy. I guessed 1200-1400lbs for my trailer (SAN210).
            Previous boats:
            2015 G23
            2008 SAN 210
            2002 XStar
            1995 Sport Nautique
            • agouge888
              • May 2012
              • 102
              • Tennessee
              • none
              #81
              Might be a pain in the butt, but you can always air down the tires half way to get a couple inches as well as drop the tongue down as suggested above, for a couple more. Would have to air them back up on lake day, but hey...a G series might be worth it and it cheaper than adding height to your 8' garage door
              agouge
              • theduke
                • Aug 2013
                • 19
                • arizona
                • 2008 230 2014 230 2015 G23 on order
                #82
                Where did you get the commercial airline trailer dolly. My new 2014 230 shows up in 30 days and that would be way easier then putting it in the garage with the truck.
                • Miljack
                  • Dec 2004
                  • 1616
                  • Charlotte, NC
                  • '08 230 TE ZR6
                  #83
                  A couple good ideas here, trailer setup to be lower via a wider stance, trailer tug, etc.
                  How about a trailer w air bag suspension? Could easily be setup to dump the 3-4"
                  2008 230 TE-ZR6
                  • Nautiquehunter
                    • Jun 2008
                    • 2080
                    #84
                    That's it! Send the trailer to Gas Monkey Garage Texas and have Aaron put in a custom air bag system.
                    • jbkriss
                      • Mar 2012
                      • 8
                      • Ft. Lauderdale
                      • 2001 SAN 210 2004 SAN 211 1985 Barefoot Nautique (454)
                      #85
                      this could be a possibility as well... http://www.trailervalet.com/ if you could get it low enough to the ground.
                      • jbach
                        • Aug 2012
                        • 187
                        • the state, not the jelly
                        • 1999 SAN
                        #86
                        here's a cheaper version. this looks like it has an adjustable attachment point, should be able to get really low.
                        http://www.amazon.com/Tow-Tuff-RTF-1...=trailer+mover
                        • jonsquatch
                          • Jul 2012
                          • 251
                          • AZ
                          #87
                          I like where your head is at there...
                          • Nordicron
                            • Sep 2009
                            • 557
                            • Madison, WI
                            #88
                            Wonder I you could order with a tower delete and have dealer put on a fct 5! Guessing that tower would lower below the dang windshield. Would have to customize the cross section but according N3 boat works that's not to hard a job.
                            • Zach@n3
                              • Sep 2012
                              • 736
                              • Indianapolis Indiana
                              #89
                              Eww, I don't like the FCT5 haha. We have modified center sections you just need to have someone with a very calibrated eye and measuring tape and a friend who is an excellent Tig welder then someone else who is a friend with a custom paint shop haha.
                              • nyryan2001
                                • Mar 2013
                                • 1993
                                • Lake Anna
                                #90
                                Zach, quit fooling around and post up the pics of your G21s all blinged out with 4 axel trailers!
                                2019 G23 450
                                2014 G23 550
                                2013 G23 450
                                2011 Malibu Wakesetter 247
                                2007 Yamaha AR210
