01 SAN complete power loss while cruising??
  • lakerat5499
    • Aug 2013
    • 1
    • Lewisville Texas
    • 2001 SAN
    Hi there! I have a 2001 Super Air. Last weekend, we went out for a run or two. On the way back to the ramp, Everything SHUT DOWN! Radio included. I entered my code on the keypad and everything started right back up with no issue. Little further across the lake it happened again. Same scenario. Any Ideas? I can probably eliminate fuel considering the gauges fail as well. Short? where do I start? The lake was pretty choppy which is whats leading me to thinking its a short.
    Thanks!!
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    bad / shorting out or barely making contact safety lanyard switch?
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • swc5150
      • 2240
      • Eau Claire, WI
      • MasterCraft Prostar
      Ditto what Ryan said. I've had that happen with a bump of the lanyard.
      '08 196LE (previous)
      '07 196LE (previous)
      2 - '06 196SE's (previous)
      • hyparks
        • Feb 2011
        • 302
        • Brownhills, United Kingdom
        • 2001 Super Air 210
        I had a similar issue this year on my 01 san. Mine was a corrode circuit breaker. The 3 red breakers next to the ecu - it was the top one. It was really hard to press to reset, so hard that I had to hit it with a screwdriver to get it to reset.
        Swapped the breaker for a new one and been fine since.
        Might not be the same as yours but worth a look.
        Good luck
        Sent from my HTC One using Tapatalk 2
        Current
        2001 SAN 210, GT40
        Previous
        1994 Mastercraft Pro Star 190
        • s_kelley2000
          • 1575
          • Fort Meadow Recevoir
          • Mass
          I think hyparks is on the right track with some sort of electrical issue. If not one of the breakers check the battery cables for corrosion as well. I know on my 99 if the safety lanyard is disconnected you lose power to the fuel pump but all other electronics remain on but maybe 01s cut off everything?
          Shawn
          2012 Blue Metal Flake SAN 230
          • pe4me
            • Jan 2013
            • 165
            • Dhahran, KSA/ Green Bay, Wi
            • 1997 SSN 2006 210 TE www.whitelake.com 1994 Prostar 205 (restored) 198
            Hope you get it sorted and post a follow up. Former mc had same issue and it was kill switch. Provided it didn't seem intermittent like it was starving for fuel, that is the first place to start.
            good luck, electrical gremlins are no fun.
            [COLOR=#333333]2006 210 TE[/COLOR]
            [COLOR=#333333]www.whitelake.com[/COLOR]
            [COLOR=#333333]1994 Prostar 205 (restored)[/COLOR]
            [COLOR=#333333]1986 Dixie Skier OB[/COLOR]
            • hyparks
              • Feb 2011
              • 302
              I'm sure my lanyard on my 01 san only kills the fuel pumps and not everything.
              I hate intermittent electrical faults!
              Current
              2001 SAN 210, GT40
              Previous
              • nyryan2001
                • Mar 2013
                • 1993
                • Lake Anna
                Based on what was said about the electrical breaker connectivity.... Also Check the main grounding straps and connections on the engine and around be alternator.
                several Malibu folks reporting loose grounding straps and getting issues similar.
                2019 G23 450
                2014 G23 550
                2013 G23 450
                2007 Yamaha AR210
                • hyparks
                  • Feb 2011
                  • 302
                  Also check battery connections - especially the ground.
                  Current
                  2001 SAN 210, GT40
                  Previous
                  • NautiDave07
                    • Mar 2008
                    • 333
                    • Louisville KY
                    • 00 SAN210 07 236 TE
                    my 2000 san did that and it turned out to be two small glass fuses at the battery. They were plug together connections that wore out. They were pulling apart and losing connection and were melting. I soldered in new fuse connectors and never had the problem again.
                    00 SAN 210 (previous boat)
                    07 236 te sold
