Thought some G23 /25 owners may be interested in seeing this. I had a SunStream SunLift hydraulic boat lift (SL6) and we had to upgrade to an SL8 b/c the G23 is just too heavy. Here are some pics once we got it all in. Hydraulic lines are not yet tied down and some minor details to clean up but for anyone thinking about it, i can confirm it works well:
G23 hydraulic lift
Current:
2021 Nautique G23 Paragon
2016 Mastercraft Prostar with tower
Previous:
2014 Super Air Nautique G23 XR550 / EZ Loader trailer with custom Electric over Hydraulic brakes
1996 Sylvan Special Edition 24" pontoon boat
2006 Mastercraft X2
1995 Mastercraft ProStar 190 with new dimension towerTags: None
Looks good! I also like the graphicless sides on the G. I already have that planned for the 2014 PN G23.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Why don't you use an overhead hoist? I live on Lake Houston also, and the overhead hoist is the kind I use. I haven't seen anyone use this kind on our lake.Current: 2017 G23
Quite a setup! We are in the $7k + price range for a 7k lbs lift right ?2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
Originally posted by NautiqueJeff View PostLooks good! I also like the graphicless sides on the G. I already have that planned for the 2014 PN G23.Current:
Previous:
2006 Mastercraft X2
Originally posted by OKWAKEBDR View PostWhy don't you use an overhead hoist? I live on Lake Houston also, and the overhead hoist is the kind I use. I haven't seen anyone use this kind on our lake.
I've had a hydraulic lift for 7 years now and love it. The overhead hoist takes quite a bit of time to raise and lower. I am down in about 7 seconds and up in about 20 seconds i think.
Plus it is remote control so I start lowering as I walk to the dock and when I pull in I can raise right away to catch the boat. very helpful in rough water.Last edited by c640947; 01-01-2014, 09:53 PM.Current:
Previous:
2006 Mastercraft X2
Originally posted by nyryan2001 View PostQuite a setup! We are in the $7k + price range for a 7k lbs lift right ?
So yes in considering the post about the overhead hoist (which is prob 3k) the question that is bound to be asked is it worth so much extra money to just be so much faster up and down (and safety of no steel ropes breaking and your boat falling?) I guess my response is "Did i really need to sell my old boat, which was a great wakeboat, to get a G23 550 (which cost way more) just for a bigger, better wake and no effort to set up surfing?"Current:
Previous:
2006 Mastercraft X2
Gotcha. Yes, that's much faster than my lift. Although I don't have to worry about rough water because I'm not on the main body of the lake. You can do remote controls for the overhead hoists also.
How much water does it take for one of those? I'm guessing it requires a little more water than the overhead kind (I use a cradle - not straps).Current: 2017 G23
Originally posted by OKWAKEBDR View PostHow much water does it take for one of those? I'm guessing it requires a little more water than the overhead kind (I use a cradle - not straps).
Where are you located on Lake Houston?Current:
Previous:
2006 Mastercraft X2
I love hydraulic lifts. I have used one for about 6 years now. I like the way there are no overhead anything, to take from the view out on to the lake. They are virtually maintenance free. Also, unless you need power to your dock for other things - it saves running power from your house (expensive). I will not use another cable lift again. My .02
Im in Indian Shores over in Crosby. Not sure if we've met. Last year or two I just go up early on the weekends and leave the river before it gets crowded and we surf mostly near the house. But I'm sure ill see you around this spring.
AndrewCurrent:
Previous:
2006 Mastercraft X2
Wow that's pretty slick. I dont see anything about it on their website. How much clearance above the boat does it need? Do you know how it holds up in high winds? Do you know how much the ABC retails for? Thanks in advance for all the info.
That's a smoking good price but i'm sure no freight helps.Current:
Previous:
2006 Mastercraft X2
