Hello, I purchased a older Shore Station lift for my 89 ski nautique. I need to know how shallow can the water be and still get my boat on this lift. It measers 10 inches to clear the bottom bar when all the way down and about 16 inches to clear the bunks. Thanks
If the draft is 24", and clearance for the lower bar is 10", you would need 36" depth to avoid having the tracking fins hit the bar. Draft is measured from the waterline to the lowest point, which is usually either the bottom of the tracking fins and/or bottom of prop/rudder. Just make sure to set your bunks high enough to avoid having the fins hitting the bar first.
