Swap transmission in 2013 G?
  • vision
    • 518
    • NC
    • 2013 G23
    Anyone know if you can swap the 1.48 ratio transmission in the 2013s for a 2.0 transmission? Did the prop angle, through hull angle, or position change?
    Thx.
  • TX-Foilhead
    • Mar 2009
    • 351
    • Kingsland TX
    If they didn't change the brand of the vdrive then most likely nothing else would have to change. Changing the strut wouldn't be that much more work if you needed to do that. Biggest thing is a new vdrive will probably run between $4 and 5000 and labor will probably be close to $1000. I'm figuring a day plus a few hrs for that if they had to pull the motor for the strut. Probably have to do about 3/4's of that work to get the vdrive out.
    • nyryan2001
      • Mar 2013
      • 1993
      • Lake Anna
      4k$ to achieve the type of performance that is being reported.... If a tranny swap is possible....would be well worth it IMO.
      especially for those with the 409 Gs.
      don't forget to add $1200 for the 17" prop
      2019 G23 450
      2014 G23 550
      2013 G23 450
      2011 Malibu Wakesetter 247
      2007 Yamaha AR210
      • vision
        • 518
        • NC
        • 2013 G23
        Agreed if rpms at 23mph with full ballast are the same or less.
