G 23 Prop Help
  • rons230
    • Jun 2010
    • 16
    • lake oconee, GA
    • 19 Ski Nautique 17 XT20 13 G23 09 230
    G 23 Prop Help
    I bent my prop and I was going to get it repaired, keep it as a spare and buy a new one to put on boat. Should I get something different other than the stock prop? I read the old Prop posts and all that did was prove how stupid I am. This is what I have:
    Boat: 2013 G23
    Motor: 550
    We typically wakeboard with 1/2 - full factory ballast, with 4 - 5 adults on board. We also surf a bunch. Really don't care about top end speed. I would probably never add additional ballast over stock.
    Thanks for your help
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    you likely need to stick with 15 x 14.25... likely you have the 2247 as OEM, .150 cup?
    if you want a little more tq and hole shot, get the 2249 with slightly less cup at .105. but from the sounds of it the way you use your boat its not necessary, and run 100-200 higher RPMs and use a little more gas when not necessary.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • ironj32
      • May 2011
      • 601
      • 2018 SAN G23 XR550
      Agreed.
      2018 SAN G23 XR550
      2015 SAN G23 XR550
      2014 SAN G23 XR550
      2013 SAN G23 XS550
      2013 SAN G23 ZR450
      2011 SAN 230
      2010 SAN 230
      2000 XStar
      www.mnspringride.com
