Ok looking into ordering a 230 or g21 as my dealer only has 2 g23 that are out of budget and 2 210 that only have the 343 in them.
As I am fairly mechanical I am thinking about doing some of the options I want myself to save a little budget. My questions are 1. If I plan on adding my own tower speakers is Nautique's tower prep kit worth it or just as easy to run my own wires and amp etc. 2.If I want to add a function that is controlled by linc such as the heat etc are the relays and all there and just need tapped into or would my only option be to add more manual switches? 3. is the zero off link upgrade just a add on module that could be done after the fact or is that a one time thing that should be ordered with the boat?
Thank you
Gchaney
Thank you
Gchaney
