G23 Boat lift
  • Bspot
    • Jul 2013
    • 77
    • Bonnyville
    • 2018 G23 H6 Previous: 2014 G23 XR550
    G23 Boat lift
    Bought a new G23 and in the market for a new boat lift. Is a 6000lb lift enough or should I get a 7000lb just to be safe?
  • Zach@n3
    • Sep 2012
    • 736
    • Indianapolis Indiana
    I would go 7000. If you have a lot of gear in the boat and full of fuel it will be getting pretty close to the 6000 mark. The 5400 is rated dry. My boat is the exact same weight as the lift capacity so I am slightly over. Mine is a manual lift and it's a two person job or a break and a beer then go back again. I am sure you will be going electric or something of the sort but it will be less stress on the operating pieces in the long run and probably less service work.
    • AllianceBJJ
      • Jun 2009
      • 347
      • Cedar Hill, Texas - Joe Pool Lake (Lynn Creek Marina)
      • 2013 G23 2012 SANTE 230 2011 SANTE 230 2010 SANTE 210 2006 SANTE 210
      I've got mine on a 6,600 lb HydroHoist lift.
      Current Nautique: 2013 G23
      Previous Nautiques: 2012 SANTE 230, 2011 SANTE 230, 2010 SANTE 210, 2006 SANTE 210
      • seachicken27
        • Jan 2012
        • 291
        • Bristol, TN
        • 2015 G21 2014 210 2005 210 2013 G23 1989 Ski 1998 Super Sport 1990 Sp
        Mine was on a 6600lb hydrohoist front mount. With a full tank of fuel, if I stepped onto the platform to board it, it would start to sink a bit. I would go 7k or 6600lb side mount hydrohoist
        • Live to surf
          • Apr 2013
          • 85
          • Sylvan Lake, AB
          • 2013 G23 450
          I have a 8,000 lbs Hewitt hydraulic lift. It is great. Can lift the boat, fuel, gear and a full crew.
          • robertsmcfarland
            • Oct 2004
            • 544
            • Hyco
            • 2014 g23 550
            I up graded my electric lift when i got the G23 went to two motors, and switch out cables , it is now rated over 12000 ,I did this because we keep 1000pounds of lead in at all time , and some times wait till we back to the lift to dump ballast , its also tilted back a little (lift) which helps to empty 100 % of ballast which is good for winter
            2013 G23 super air
            2010 230 super air
            2009 220 super air
            2008 210 super air
            2005 210 super air
            2003 calabria pro air
            • GCSuper
              • Jan 2010
              • 292
              • North Texas
              • 2011 Super Air 210 2015 Super Air 210 on order
              Always a good idea to have a little extra capacity. When we upgraded to our 210, I had a 4K Shoreline. The boat dry weighs 3800 so I was at the limit with fuel and gear. During high winds or excessive boat traffic, the lift would sink down putting the bottom of the boat in the water. Caused a lot of worry so I sold it and up graded to a 5K lift HH. Have had it three years now, and even it has dropped down a couple of times during extreme winds. My dock is exposed to the north and can get blasted, so I now wished I had gone to a 6K. You never worry about too much lift, but since our lake house is over an hour away I can worry plenty about not enough.
              • Zach@n3
                • Sep 2012
                • 736
                Just like building a garage. You are going to build it to store more than just your boat haha.
                • shag
                  • 2217
                  Always go heavier. I love the hydraulic lifts - no cables, very clean install.
                  • atthelake
                    • Aug 2011
                    • 9
                    • Saskatchewan, Canada
                    • So close a couple of times now...
                    Floe VSD 7500 24Volt. Go with a 27 or 28' canopy with extensions. You'll never regret it!!
                    • sja
                      • Jun 2012
                      • 66
                      • minneapolis
                      • 2013 Nautique G23 XS550
                      Hewitt 8000 24v for my g23. Quick and clean. Nothing to climb over to board the boat.
                      • c640947
                        • Jul 2013
                        • 112
                        • Badin Lake, NC
                        • 2021 Nautique G23 Paragon ///// 2016 Mastercraft ProStar with tower
                        I had a a hydraulic sunstream 6000 pound lift and it wouldnt lift my G. I have the 8000 pounder now and it lifts it no problem.
                        Current:
                        2016 Mastercraft Prostar with tower
                        Previous:
                        2014 Super Air Nautique G23 XR550 / EZ Loader trailer with custom Electric over Hydraulic brakes
                        1996 Sylvan Special Edition 24" pontoon boat
                        2006 Mastercraft X2
                        1995 Mastercraft ProStar 190 with new dimension tower
                        • vision
                          • 518
                          • NC
                          • 2013 G23
                          Boat. House lift or ground lift? My 6k boat house lift works great. Keep it greased. Center pulls require far less amps than double motor lifts. Also, make sure pilings are good if you have decent water depth. If you are using a ground lift, ignore this post ; ).
