Plug and play on a 210
  • cedarcreek216
    • Oct 2009
    • 1009
    • Dallas, TX
    • 2018 210 2013 210 2009 216V
    I'm not sure I am real clear on the tube thing. Do you have any photos?
    • Nordicron
      • Sep 2009
      • 557
      • Madison, WI
      Please check out this thread for info on how to prevent collapsing your hard tanks:
      http://www.planetnautique.com/vb3/sh...ad.php?t=26217
      • cedarcreek216
        • Oct 2009
        • 1009
        • Dallas, TX
        I guess I'm dumber than most but after reading that thread I'm still not real clear on the 1/4" tube. Does it run all the way through the bag or just enough to let the bag breath when it being sucked dry?
        • Nordicron
          • Sep 2009
          • 557
          • Madison, WI
          Yes it runs through the bag. It runs from the fill inlet hole of the bag through to the vent hole. It's tied off to each fitting so it stays in place. It's purpose is to keep the bag from sucking totally flat which cuts off the ventilation for the tank. Hope that makes sense.
          • cedarcreek216
            • Oct 2009
            • 1009
            • Dallas, TX
            Gottcha. The reason for tying it off is to keep it in place because you put it in the active drain and fill line.
            • Nordicron
              • Sep 2009
              • 557
              • Madison, WI
              #21
              Exactly. Make sure that you make the tube long enough so that when the bag expands with water it doesn't pull the tube free.
              • Shockthis
                • Mar 2013
                • 302
                • Christina Lake BC
                • 2021 centurion ri245
                #22
                Could you just add a in line non return check valve backwards in one of the extra holes on the sack? This way it would allow more air into the bag. Just install it right about the fill hole. Just a thought
                http://www.wakemakers.com/marine-check-valve.html
                • Nordicron
                  • Sep 2009
                  • 557
                  • Madison, WI
                  #23
                  I don't believe that would do it. What happens is the bag collapses on itself and that's what kills the ventilation. Somebody floated an idea out there to add a vacuum relief valve to the tank but I'm not sure if anyone ever found one that would work well enough to not allow air to enter the system.
                  • josemolino
                    • Feb 2011
                    • 235
                    • Barcelona Spain
                    • 2014 G21 2007 SAN 220
                    #24
                    That´s the one available from Flyhigh. It works great and still leaves room for vests. You fill/drain stock with one push and then teh extra with a second one.
                    Originally posted by Silver Surf View Post
                    I'm in the same boat. I have a 06 220 that I want to add a piggyback system. From my understanding many people are going with the 750lbs sac's in the rear over the 400lb. Since the larger bag will fit.
                    • ffmedic74
                      • 835
                      • Lexington, KY
                      #25
                      Can someone take some pics of the new factory system with the extra soft bags and how it works etc.
