setting up the g23 for wake surfing
  • thomas
    • Mar 2014
    • 15
    • United States
    • 2018 2018 G23 2016 G23 2014 G23 2013 230 2008 236
    I just traded in a '13 230 for a 14 g23 and wanted any comments on the set up for wake surfing. We had a good wake with the 230 using nss and 750 lbs on port, 400 lb on starboard and about 400 in the bow plus all the ballast the boat came with. I assume we won't have to add any extra ballast with the g23, but would love to see what other people have tried. Thanks
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Roughly a 60/40 cheat to the surf side:
    11.4 - 12 mph
    NCRS 3-5
    NSS at 2-4
    full OEM ballast
    1100 in surfside trunk
    300-750 in other trunk
    200lbs pop lead in the bow
    ^^^ this is how we run 75% of the time (3500rpms) around 12gph
    when we really go heavy(4200rpms) around 15+ GPHs add:
    1000 other trunk
    750 in the bow
    when my 9yr old son surfs, OEM ballast only, 2600-2700rpms
    NCRS 5
    NSS 3-5
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • nyryan2001
      • Mar 2013
      • 1993
      • Lake Anna
      75% setup:
      Heavy:
ID:	368046Click image for larger version
      Kiddie OEM Ballast:
      2019 G23 450
      2014 G23 550
      2013 G23 450
      2007 Yamaha AR210
      • thomas
        • Mar 2014
        • 15
        • United States
        thank you, the wake looks huge, especially on the off side (starboard) of the prop wash. Did you plumb in the extra sacks? We usually have 8 to 10 adults with us , and I hope we can weight it primarily with people and not a lot of extra sacks. We have been doing the sack thing for many, many years and it is kind of a hassle, but you do what it takes. Thanks again!
        • nyryan2001
          • Mar 2013
          • 1993
          • Lake Anna
          Yes definitly plumbed, Tsunami pumps are a PITA. All bags under seats or in compartments.... except when we sometimes opt for the additional 1100 triangle in the bow. 1100s pumbled in off of a Y valve using existing pumps and exisiting thru hull. not a single hole to be drilled thru my fiberglass. OEM ballast fills, throw a valve then the "piggy" 1100s fill sequentually off the Y'd OEM port/starboard pumps. the overfill relief is Y'd into the existing OEM overfill thru hulls on the down hill gravity side right before it exits.
          Not sure where you live...but Blanton at Buxton Service Dept has plumbed my last 2 boats and he really knows what he is doing.... not a single kink, air burp, issue or failure in his setups once... and I use it every time we go out.
          2019 G23 450
          2014 G23 550
          2013 G23 450
          2007 Yamaha AR210
          • Bspot
            • Jul 2013
            • 77
            • Bonnyville
            • 2018 G23 H6 Previous: 2014 G23 XR550
            Did you have to get the timers reprogrammed on the link screen?
            • nyryan2001
              • Mar 2013
              • 1993
              • Lake Anna
              No need to.... the 1100s filled to their max in the compartments are around the same as the 3 OEM 950lb sacs. Very very close.
              2019 G23 450
              2014 G23 550
              2013 G23 450
              2007 Yamaha AR210
              • Bspot
                • Jul 2013
                • 77
                • Bonnyville
                so then you have to push the fill twice???
