Any tips/suggestions for installing a depth finder in a 91 SN. More specifically pulling the clock and associated wiring and installing the depth finder in its place. Thanks.
RE: Depth finder install
You will want to check the power on the clock to make sure it's not a constant hot wire, I don't think it is, when you power off your boat if the clock keeps running then the power wire is constant hot, so you will need to use a different source of power so the DF doesn't stay on when the boat is off. If this is the case you can use one of the power wires from one of the other gauges to supply power to the DF. If the clock stops when you power off your boat then you can use that wire for power.
I have a 91 SN and the clock only stops when you turn off the ignition breaker.Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
Yeah, that's how my '94 was too.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
darrel409 i am about to replace the clock on my '85 sn2001 with a DF.if u want it let me know.
When I installed my DF I replaced the voltmeter since the PP has a built in digital voltmeter that's more accurate. Just another option if you like your clock and have a PP.
On my 94, my clock runs whenever the ignition switch is on. I would wire it to a keyed power instead, since I need to leave my ignition switch on for my auto-bilge to work. This would leave the DF on any time I left my boat in the water. I'd rather have it come on when the key is in the on position, like I wired up my perfect pass.
just an idea.
B
