Rear Drain Plug
  • sean950054
    • Mar 2010
    • 55
    • 97 Ski Nautique 196 98 Air Nautique 06 Air Nautique SV211 Intrepid 339
    Rear Drain Plug
    Has anyone come up with a solution on installing any sort or ball valve or way to have a rear drain plug where you can open it up without having to physically remove the rear plug? My boat is on a life so accessing the rear plug is hard to do with it getting wet. Here in Florida whenever extra water sits in the bilge it gets pretty gross and the bulge pumps
    Never get it all out.
    My thought is to install a valve from the inside going out that I can manually open or close to let the extra water out.
    Thoughts?
  • Zach@n3
    • Sep 2012
    • 736
    • Indianapolis Indiana
    Inflatable dingy??
    • s_kelley2000
      • 1575
      • Fort Meadow Recevoir
      • Mass
      Something like this might work for you:
      http://www.seasense.com/index.php?pa...mart&Itemid=27
      If your boat is always kept on a lift and never moored then this is probably safe but I have zero experience with a product like this.
      Shawn
      2012 Blue Metal Flake SAN 230
      • Zach@n3
        • Sep 2012
        • 736
        That was my poke at not having a good idea ha. Sounds cheap, but what about just an expandable rubber plug from the inside out? Plenty of boats don't sink with those in the drain plug holes. Another thought would be to buy and modify another drain plug thru hull fitting to fit on the inside. Cut the threads off the back of another for the outside piece so it seals to the hull and looks stock but thread the drain plug in from the back side out. Don't know if it would work. Seems like a lot of trouble.
        • josemolino
          • Feb 2011
          • 235
          • Barcelona Spain
          • 2014 G21 2007 SAN 220
          As one of my bosses used to say.... "The Best is enemy of the Good".
          Keep it simple and go for a proven over the shelve solution
          • 4th ski-doo
            • Apr 2013
            • 307
            • Wilmington
            • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
            I was considering connecting a longer hose to reach the drain
            2013 SANTE 210
            2011 Sport 200 V
            1994 Bimini Skier Pro 190
            • sean950054
              • Mar 2010
              • 55
              I was thinking of somehow doing a ball valve fitting that could screw
              In from the inside to out and then I could open an close the ball valve fitting? I agree on something simple.
              • rcazwillis
                • Feb 2014
                • 117
                • Fort Worth, TX
                • 2002 SANTE
                Trucks (big rig) have spring loaded drain valves on the air tanks. A cable is attached to the valve. Pull the cable and the moisture is drained out of the tank. You could put one on the inside. Pull the cable and the valve is open, water drains. Release the cable valve closes.
                Sent from my DROID RAZR using Tapatalk
                • sean950054
                  • Mar 2010
                  • 55
                  I like that idea. Would that spring loaded valve be able
                  To somehow be attached or
                  Screwed into the drain plug? Where am I able
                  To get stuff like that?
                  • rcazwillis
                    • Feb 2014
                    • 117
                    • Fort Worth, TX
                    • 2002 SANTE
                    It would have pipe thread, but might need an adapter to get correct size. Any truck stop or truck repair shop will have them.
