2014 g23 - surf and wakeboard questions
  • Dukeboiler
    • Mar 2014
    • 40
    Hey guys. Posted that I'm new to nautique and getting a g23. Picked it up Friday (pictures coming) and spent all weekend on it. LOVE it!! Wow, what a boat - a real beast. I do have a couple of questions - mostly about setup.
    1. When pulling my kids wakeboarding between 17-18 mph (beginner to average skill set) only one side of the wake is clean, and it is very sensitive to passenger distribution. I played with ncrs but not much different. I also had NO ballast filled. Any thoughts on how to get a clean wake on both sides for the little guys?
    2. For surfing I put ncrs on 5, NSs on 5, and full ballast tanks, and it was great. Just checking for any fine tuning here - if I'm predominately standard surf should I not fill the stbd side? Or vice- versa? Any other tips?
    Sincerely
    Hooked neophyte.
    Using Tapatalk
  • NautiqueJeff
    A d m i n i s t r a t o r
    • Mar 2002
    • 17125
    • Lake Norman
    • Mooresville, NC
    You've got a great boat there!
    On your first question, you really need to go at least 19 - 21 MPH in order for the wake to be clean behind the G23. Shorten the rope up to 55 - 65 feet. Be sure to weight the boat evenly. That should clean it right up. On the NCRS settings, please just leave it on AUTO and set the intensity on HIGH. There is really no good reason to ever change this (except when surfing). The computer will always keep NCRS on the optimal setting, and if you don't know what you're doing, manually configuring the NCRS while wakeboarding or pulling any rider at speed can actually be quite dangerous. I have owned many Nautiques over the years, and I have been in tons of G-Series boats, and I have never ever found a reason to operate NCRS manually when in wakeboard mode.
    For surfing, you've got your NSS settings backwards. The best surf wake from the G23 will be at 10.8 - 11.3, full factory ballast (all, not just surf side), NCRS between 3 and 5, and NSS at ZERO. Running NSS at 5 is its LEAST-ENGAGED setting, and I would not recommend that.
    Another tip - when you're NOT towing a rider, use the BACK TO DOCK setting instead of just turning Zero Off off. That way, NCRS stays engaged (in AUTO) and helps the boat's performance and ride.
    • nyryan2001
      • Mar 2013
      • 1993
      • Lake Anna
      Yes they are somewhat weight sensitive..... get your passengers to sit stilll and stay put...... add a little ballast to the side thats washed out. easy fix.
      Post up a pic of your wave, my setup varies greatly from Jeff's, we run faster as we have bigger guys, they need the speed:
      11.6- 11.9mph
      Full OEM ballast
      1100 in the surf side trunk maxed out
      300-500 in the other trunk.
      200lbs lead in the bow
      NCRS 3-4
      Surf Vert 2-3
      All of these guys are big 200lb+ over 6ft
      2019 G23 450
      2014 G23 550
      2013 G23 450
      2011 Malibu Wakesetter 247
      2007 Yamaha AR210
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        And for kids or beginners, NCRS 4, Surf Vert 2, full OEM ballast... maybe 500lbs in the surf side trunk. 11.4mph
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2007 Yamaha AR210
        • wakeslasher69
          • Feb 2013
          • 169
          • Durham NC
          • 2016 G23 (550 HP)
          I do like Nyryan's set up for a long session with advanced surfers. However the additional weight isn't "necessary". I'm 215lbs and ride just fine with stock setup with maybe a slight cheat of "boat meat" to the surf side. You do need your NSS on full deployment with the NCRS on auto (makes the boat plane out much faster). The only prob with nyryan's setup up is that it removes the ability to just switch sides on the fly, and I always have a few goofy foots in the boat. If you need more size on the wave slow down a bit, for my size I run around 10.5-11. A lot of surfing is technique along with your board choice. Get your technique nailed and you will be able to ride almost any size wave. Aggressive boards are going to be MUCH harder to hold in a pocket and carve. That said, I would LOVE to ride nyryan's monster wave! (For reference I'm in a 2013 G23 with the 550)
          • ironj32
            • May 2011
            • 601
            • 2018 SAN G23 XR550
            I've had success getting a clean wake at that speed. Try adding a little bit of ballast to the side that is washing out. While driving, just let the ballast fill on the bad side until it cleans up.
            2018 SAN G23 XR550
            2015 SAN G23 XR550
            2014 SAN G23 XR550
            2013 SAN G23 XS550
            2013 SAN G23 ZR450
            2011 SAN 230
            2010 SAN 230
            2000 XStar
            www.mnspringride.com
            • micjhiu
              • Jan 2013
              • 10
              • Midwest
              • 2013 G23 450 hp w/ NSS 2005 210 Super Sport
              NSS at ZERO? Did they change that for 2014? Last season we had it set around 3-5 depending on how many people were on the boat. We assumed that when it was closer to 5, the blade was extended out or fully engaged on one side.
              2013 G23 450 hp with NSS
              • philb
                • Jan 2009
                • 125
                • Australia
                No changes.... As Jeff said, NSS at 0 is the most engaged (extended). We run NCRS at 5 & NSS at 3. Sometimes we'll mess with NSS between 0 & 3. But 5 & 3 will guarantee a great wave.
                Depending on people we run about 2000lbs of plumbed in extra ballast, but with or without extra ballast 5 & 3 will get it done for you....
                • Live to surf
                  • Apr 2013
                  • 85
                  • Sylvan Lake, AB
                  • 2013 G23 450
                  I too thought NSS at 0 was least extended and 5 was most. When I am using stock ballast and NSS 0 the wave is long and low as I increase to 5 the wave gets steeper and shorter. I thought that was due the NSS diverting more water as it extended farther into the water.
