210 2013 nss set up
  • Shockthis
    • Mar 2013
    • 302
    • Christina Lake BC
    • 2021 centurion ri245
    210 2013 nss set up
    Sorry, I did see this before some wear on this site, but can not find it now. What is the set up for a 2013 210 for surfing.
    Thanlks
  • cedarcreek216
    • Oct 2009
    • 1009
    • Dallas, TX
    • 2018 210 2013 210 2009 216V
    Do you have any extra ballast or stock? If stock fill them all and set NSS to zero and hydrogate pulled back and start at 10.5 mph and go from there.
    • Shockthis
      • Mar 2013
      • 302
      • Christina Lake BC
      Going to have 750s in rear and bow sac 450 front
      • cedarcreek216
        • Oct 2009
        • 1009
        • Dallas, TX
        Then I am pretty sure the sMe theory applies, fill them all and go. I know without the extra bow weight and extra 400 in each rear locker we had favor surf side weighting a little. This should not be an issue with extra bow weight.
        • iamcdn
          • Mar 2013
          • 337
          • Penticton, Canada
          • 2013 SANTE 210 with NSS
          http://www.planetnautique.com/vb3/sh...ystem-on-a-210
          It's been so long I can't even remember what I did. Snowing again here today...ugh
          • F725
            • Feb 2013
            • 381
            • Minnesota
            • 2018 G21
            The 2012 / 2013 210's with NSS like a little more weight in the port locker and side than the starboard. If your switching side to side, a very slight lean to the port side will make a great wave on both sides... If your just surfing port side, fill all tanks and add an extra 500 lbs to the port locker and side and your wave will be insane! Same rule applies to just surfing starboard. NSS was usually run around 3 for port, and 2 for starboard. Speed at 10.5 and fine tune with the Hydrogate.
            • Shockthis
              • Mar 2013
              • 302
              • Christina Lake BC
              I have both straight line 750s and fly high 400s which ones should I install for extra ballast on my 2013 210? I have a ibs as well that is being put in.
              • cedarcreek216
                • Oct 2009
                • 1009
                • Dallas, TX
                It sounds like the 750's fit but it has to be a tight squeeze. They are 4" taller and wider and 8" longer than the 400's I have in mine and mine seems full. If you have the 750's why not use those.
                • OKWAKEBDR
                  • May 2005
                  • 750
                  • Lakefront
                  • 2017 Super Air Nautique G23
                  I have 750s plumbed in on top of the stock ballast in the rear compartments and the u-shaped bow sack plumbed in under the front seats. Surfing (with NSS) or wakeboarding doesn't matter. Just fill them all as full as they will go. A slight lean to the port side for surfing is needed. I do this with a few pop bags. The wake is really really good.
                  Current: 2017 G23
                  • lucky7t
                    • Mar 2011
                    • 1306
                    • Oklahoma
                    • 2015 SANTE
                    210 2013 nss set up
                    Filled all stock up , nss at 4 hydro gate all the way back and could of surfed across the entire lake. I got a crick in my neck I surfed so long lol..
                    With stock ballast it looks like about 300 lb extra ballast. I'll agree with everyone that it favors the starboard side. I added 100 pounds of weight to port side and it cleaned up
                    Current Correct Craft Boat
                    Correct Craft Boats Owned
                    • cedarcreek216
                      • Oct 2009
                      • 1009
                      • Dallas, TX
                      We just empty a little out of the starboard side instead of adding hard weight or an extra sac. That gets you the slight lean you need. People weight will work too.
                      • jonsquatch
                        • Jul 2012
                        • 251
                        • AZ
                        Mines a 2012 210, I pulled the hard tanks (~278 each) in the back and put in 750's (more weight still have storage when full and it makes maintenance a breeze), with the 750's full and the belly tank (350) full plus 300 lbs of bomb sacks under the seats up front with an average size driver at the helm (maybe what 160- 175?) and 200lbs of bomb sacks on the rear port seat and 3 women (No guesses on weight since I want to live) on the port side at ~10.3 with the NSS on 1-2 a 300lb dude on a Hyperlite Landlock can drop the handle and ride. The lower the number on the NSS the better for me on the port side. I like adding extra weight over draining since with the NSS the extra weight on the plate side seems to make it more effective.
                        When we have someone who wants to transfer from side to side I still need that 200 lbs on the port seat or at least 100 of it plus the other 100 on the floor, although I have a bit more driver weight to offset than most. The goofy wave seems to like a higher setting on the NSS and a little more speed but for transferring a rider I might start at 10.4 at 2 with the passengers mostly to the riders side and as soon as the rider signals to transfer they start to slide over as the boat transfers.
                        • Shockthis
                          • Mar 2013
                          • 302
                          • Christina Lake BC
                          If I pull the tanks does the link system still show how full they are? Can you still use the feature for individual riders setup?
                          • cedarcreek216
                            • Oct 2009
                            • 1009
                            • Dallas, TX
                            The LINC does not really show how full they are. It shows how full they are based on full and drain time which is out the door once you add extra sacs. That's the crappy part about times full instead of float measured full. If you have everything included piggy back full then start draining piggy back LINC shows stock tanks emptying. Sucks because you never know when everything is empty which is how I collapsed a hard tank.
                            • jonsquatch
                              • Jul 2012
                              • 251
                              • AZ
                              Yep once you add extra ballast, be it piggy back or bigger bags in place of the hard tanks the system levels go out the window. They were never accurate in the first place, if you get an obstruction in one of the lines or the impeller is starting to go or there is a bit of an air leak or someone shuts off the valve at the through hull the system still reports that its filling/filled when that isn't the case. Or when the impellers are starting to go it shows it as empty when you still have a 1/4 tank of water sitting there.
                              The worst thing is there are sensors in the tank, it just only uses them when you first turn the power on so it knows the current level then it uses the timer from that point on. So even with the sensors disconnected with the tanks pulled using bags the levels are nearly as "accurate" as they were before and it still shows them filling or emptying as it did before. I only loose the ability to know if there is water in them on start up but since I can tell if the bags still have water in them easily when emptying by just looking I don't really have that problem.
