Differences between 2004 and 2007 SV211?
  • Alpine331
    • Aug 2013
    • 21
    • Banff, AB
    • 2023 GS20
    I'm looking at ordering a new cover for my 2004 SV211 but Outer Armour only has patterns for the 2007-newer sv211. does anyone know which changes occurred to the 211 from 2004 to 2007 that might affect the fit of the cover? Did Nautique change the FCT in 2007?
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    I know that in 07 you could get the Titan tower as an option on the 211 but the standard FCT looks to be the same between 04 and 07. I am not sure if the deck changed in 07 but I don't think it did. I think they made some minor interior changes but nothing that I know of that would affect the fit of a cover. I think as long as the pattern they have is for the same tower as you that you should be ok but I don't know that for a fact.
    Shawn
    2012 Blue Metal Flake SAN 230
      • 2908
      The 2004 had very thick seat padding, they reduced it to thinner padding 2005+ so people would sit deeper in the hull (maybe to make parents feel like it was safer for kids). The interior on the 07 has seatbacks raised above the hull too. I think they also changed the rotation of the prop (different transmission) and changed the ballast pumps eliminating the valves and side hull discharge. The 2004 came standard with a teak platform, in 2007 the fiberglass was standard but either could be ordered both years. The 07 also has stainless steel cupholders and LED interior lighting too. The radio in 2004 was a Clarion XMD3 (oval remote), in 2007 it was the CMD4 (round remote). The 04 had a 65 amp alternator, the 07 has a 100 amp alternator. Graphics in 04 looked like an orb, in 07 they had tribal flames (thankfully short lived). Somewhere around 2008 they also changed the tower mounting feet of the FCT's, as well as offering spinner racks by Titan. In 2008 the Excalibur motor went from 330HP to 343HP and speed control went to zero off.
      That's all I can think of.
