Fixing Gel Coat Scratches
  • FLCERIK
    • Jun 2005
    • 68
    • Reno, Nevada
    I have a few scraches in the gel coat and want to remove them. I tried using a rubbing compound and it did not work. How do you remove the small scraches?
  • BozBoarder
    • 77
    • Heber City, Utah
    RE: Fixing Gel Coat Scratches
    You might try wet sanding with 1000 grit wet sand paper and then use a cutter polish with a electric or air polisher.
    2001 Super Air
    • DavidF
      • Sep 2004
      • 611
      • Austin, TX
      1000 grit paper will not do much to gelcoat due to its hardness. If the scratch is not too deep, start with 600. If a deep scratch (not through gelcoat) start with 400. Either way, graduate to 800, then polish with course compound like Boz said.
      • WakeUpDude
        • 104
        • SLO County
        Graduate with at least a 1200+ grit sandpaper. The higher you go, the smoother the end result will be.
        Also remember to sand in every direction, and keep sanding a good 2-3 inches away from the actual scratch, or you will get a pit in the gel coat once you finish.
